Here IT IS FINALLY! NAND UNLOCK AND REFLASH TOOL!
OK got it to work! Finally! You MUST remove HTC Sync from your computer or it will block it from flashing the custom recovery.
it took me less time to root the phone than to get this "easy" tool flashed on. hang in there remarsh2003. just keep at it. thing was tickin me off til about 2 minutes ago. now it works great. if i had this much trouble with this tools help i probably would not have been able to do this at all. thanks Unrevoked!
HTC Sync does not mix well with the reflash tool. Aslong as you have the drivers installed the i listed in the other thread then you will be fine. BE SURE TO REMOVE SYNC! This tool works like a charm if you do it correctly, they could not have made this any more easy for people. I love not having sense ui anymore and having just regular vanilla android :)
where did you get vanilla rom?
Has anyone flashed with HTC sync still installed? I finally got root and in the process of pushing recovery should I abort and remove sync or just wait?
worked like a charm
stock rom + unrevoked root + unrevoked recovery + custom rom of your choice .... hell yeah doesn't get any easier
Worked great, got everything to work with removing sync. Thanks b. How did you remove sense
Sent from my ADR6300 using Tapatalk
dumpsterrentals79
