Hi.. my name is Fernando..
The only lag I notice on LP is when I go from portrait to landscape and vice versa. I have 5 home screens, 3 docks, BW home, engadget widget, AC widget, and the Facebook and Twitter widgets. Scrolling is smooth. Oh, sometimes when I hit the home button it takes an extra second for the widgets to show up, but NBD for me.
EDIT: I'm running vaelpak 2.2 with the kernel that came with the ROM.
Grrr.. no people widget with adw... sigh.... is there a decent people widget in the market that I can trust? Also.... CM doesn't reformat the text when you zoom in and out??
The zoom is a setting you need to check off... I forget what its called...
And Try Reflashing Smooth again thru Rom manager...
It should work fine... I just tried it again here and it works good...
Ok... where and how do I get different sounds in CM. :mad:
Wtf were they thinking with these sounds? :confused: The rom is great. Still some things I don't like about it, but overall it's good... But honestly, the sounds is about to be added to the list with 4g and no hdmi for why it'll never be my daily. Those sounds are absolutely terrible. And the ringer... seriously? :confused:
LoL you can use Root Explore to thru in whatever Sounds you want calm down... Its a bare bones system
Lol I've had a really bad day today so far. Those annoying sounds didn't help. Is there a way I can pull the sounds from another rom and put it in CM?
But of Course... Vael? Let me see what I can find...
Update: Here you go... Audio goodness from Vael...
Unzip this... and Copy the folder you extract to your SDCard
Use Root explore and copy the file from the SDCard
In Root Explorer go to system and paste this file...
It will say this file exists bla bla just push it thru and new sounds will be available after that...
Reactions: Jerzyiroc
whats the best stock rom...just stock with root...and also is it possible to flash stock rom(no root) and thats it you just loose root?(incase i got to sprint)
__________________
He didnt ask for the RUU...
and to answer the Question Yes you can... on both situations but its preferred you actually return to stock if you need to being the phone back for any reason
if i flash the RUU im instantly stock or stock with root?
Ashok Dharshan
