High Battery usage from Android OS
wildman082
7
Android OS is regularly using 25-30% of my battery which is much higher than my previous two phones. It's using more than the screen itself. Anyone else having the same issue? I did a wipe and I'm having the same results. I installed Better Battery Stats but I'm still trying to figure out how to read it.
Unfortunately this seems to be a common issue amongst all of the new moto devices. Results in pretty bad idle drain off 10-20% overnight.
Sent from my Nexus 7
My top two are always Screen and Android OS as well, and they're both usually in the 30%s. I don't know if it's just Motorola or what. Battery life has been pretty good for me, so I mean percentages don't mean a whole lot. However, if it is fixable and I can get even better battery life, I'd be all for it.
fistyjone
