High volume notification when plugging in headphones or aux cable
hawkeye680
54
When I plug my aux cable into the phone, and then attempt to turn the volume to the highest setting (music sounds better through head unit that way), it gives me a warning about the volume and then turns it back down. I have to turn the volume back up. Is there any way to turn this off?
Yes there is,, I have seen it and even turned this off. Feeling stupid,, don't remember how I came across the setting,, I will try to find it but rest assured,, you can turn it off, I have
THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
If you do remember, post up please.
The only way I've found to bypass the high volume notification was to root, install Xposed Framework & Wanam Xposed then placing a check mark in the Disable Loud Volume Warning option found under Sound.
Sent from my SM-N900T using AC Forums mobile app
I am feeling a bit like Zmann. I too turned it off on my Note 2,but have yet to find it on the Note 3. It's there, I will keep looking
Not sure if it's related, but I have the same problem with volume cut in and out with GMusic equalizer turn on. Once I turned off equalizer, all songs plays fine.
I think when the message popped up it gave me option to check the box that said "don't show this again",, pretty sure that's how I did it.
tuovst
