Home screens... Let's see what you got.
I actually did not know that, thanks for the info, it does look much better without the search bar.
And yes, stock launcher.
your main screens are very functional lately mate :)
i tend to go for prettyness, although the dock has 10 apps in it, and the rest of my screens are a jumbled mess lol... organised chaos :)
howd you change the colour of GSam btw?
global s3, UK. Ask me anything and ill reply even if its just an intelligent (or stupid) guess ;)
Lol, thanks
Open the app and go to settings and you should see widget settings in there and then you open it and click the colors and a color icon should come up
I used to use physical buttons, and then I found button savior
-S. T. C
Sent from my rooted, debloated CM10 jelly bean 4.1.2 Samsung Galaxy S3 #LikeABo$$
Update after suggestion posted above, much better.
just discovered the new JB feature to hide app icons in status bar :)
got a nice tidy statusbar now
such a great feature
Will have to take advantage of that when jelly bean is pushed to my device.
Uh that doesn't actually work, I believe that a call disables the app from doing what it's supposed to do
I forget which app I didn't that to, but the app stopped running
I believe it was avast
-S. T. C
-S. T. C
ive tested them all mate :) ive only hidden the ones that put icons on status bar (wave control, dock4droid, that ascending ringtone fixer)
i ditched Avast when i realised the battery use btw.
i just use AVG, Zoner and App Brain Ad Detector :)
.....do you mean when someone calls, it deactivates the apps mate?
il have to test that 2moz...
Simple and "modern" ;)
Sent From My Rooted/Modded SGSIII - If I've helped you please click 'Thanks'!
Sent from my SPH-L900 using Android Central Forums
Well it doesn't work for me, I just did it again and it removed my power widgets from my status bar, and I had to restart the app
It doesn't work on apps that give you constant notifications like avast, widgetsoid and others
-S. T. C
Dronevex
