Honeycomb on GTAB
Yeah I know about those sites but thank you tho. For my other question does the honeycomb port use the sd card as the main sd card or does it use the internal storage as the sd card by default? To be more clear I'll give an example. When u download something off the web does it go to the sd card or to the internal storage?
Sorry I didn't answer your question that was mostly just general frustration about my install & some tips for those wanting to install. Also I thought CM7 was a 1.1 rom?
To answer your question, the first time I booted it scanned and mounted the internal storage. When I clicked the notification tab it showed as an sd card which I accidentally unmounted. I'm not using an sd card. Obviously I couldn't download anything then but once I rebooted it used the internal. No need for an SD.
Ok... If I do decide to try it out I will have to switch data from internal to sd card and vice versa which kinda bites since I play alot of gameloft games and other games that use the sd card... yeah I'm just gonna stay with cm7 and patiently wait. Thanks for all the information tho.
Taylor Bag
