Question How can I power on my phone when my power button is broken?
musfiq1717
I am using Samsung M33 phone and my power button along with finger print button is broken. For now I dont want to change the power button as I am on a budget but I also want to solve the problem. currently I just set the screen timer to always on but I worry that if the phones drains of chrage or somehow turns off then how can turn it on back. note:- the volume buttons also doesnt work and I have a pc. Is that anything that I can do with my pc by connecting it to the phone to turn on the phone?
Hi Musfiq,
Try these options:
  1. ADB Commands: If USB debugging is enabled, connect to a PC and use adb reboot to restart.
  2. Auto Power On: Plug your phone into a charger; some devices turn on automatically.
  3. Scheduled Power On: Set a scheduled power-on time if the phone is on.
Hope this will help you and resolve your problem.....:)
Reactions: Fulani Filot
Hi Musfiq,
Try these options:
how would I understand if usb debugging is enabled ? I can't find it anywhere in the developer options. my phone has default file transferring option for usb plug in, there are other options also like usb threatering, MDI etc. but not usb debugging. earlier I have tried this on my another phone but the ADB doesn't work. How can I be sure that whenever I plug in usb to my pc when it's off I can use the ADB commands to turn it on?
There are multiple problems with your phone -- several buttons are broken (physical damage) and you're not able to find the long-standing USB Debugging option in Developer Options (software corruption). I realize there's a budget issue but you're trying to keep a badly damaged phone working like it's not. At some point it's time to stop wasting your time and efforts, and by a new replacement phone. (..... with a good, rubberized case).
RangelS25
