How can I tell if its the battery problem or motherboard problem?
  • Start date Start date
A
Android Central Question
I'm using LG G Pro 2 (model f350l) with Li-ion (removable) battery.
The battery drained from 100 to 0 in 2 hours and constantly overheated even without using. The battery is not bloated or swollen.
The phone can be charged and there's no heat while charging. ON/OFF and everything else is working fine.
I often left the phone charging overnight leaving it overcharged. I've read somewhere that lithium battery will stop the charging when the battery is fully charged.
I wanted to get a new battery but am not sure if its the battery that's damage and needs to be replaced or is it a motherboard problem.
How can I tell whether its the battery or motherboard problem?
Appreciate your expert advice.
All chargers are automatic, so you didn't overcharge the battery. What happened is you were leaving it at a high state of charge, which is above 75%. That, and draining below 30% are the two biggest killers of Li-ion batteries, and the general guideline for phones is to keep it between 40-80% for longer life. I think your battery is probably going bad, not the motherboard.
I'm not an expert, but I did stay at a Holiday Inn once. These guys, on the other hand, are experts.
https://batteryuniversity.com/index.php/learn/article/how_to_prolong_lithium_based_batteries
Usually charging to 100% is okay, because the charger (the circuit inside the phone - the thing you plug into the wall is just a power supply) stops the charging at 100%, then kicks in if the battery falls below about 98% and tops it off. (If the circuit goes bad, that can cook the electrolyte out of the battery and destroy it.)
If this is the original battery, it's going on 5 years old and almost definitely shot. (Take it out, put it on a flat surface and try to spin it. If it makes even one full turn, it's swollen.) But I've run my batteries between 40% and 90% for years, and never had a problem with longevity. (That's not to say that they never go bad, they do. And 5 years is 2 years of gift.)
One day we'll see better lithium technology - the auto industry is spending billions (that's with a "b") trying to get all the bugs out, because replacing a battery in an electric car, if it's still under warranty, is something no manufacturer ever wants to do (and owners wouldn't be thrilled paying the $5,000 it will cost if it's out of warranty). They 're also working on reducing the weight to power ratio, so some day we may see phones that can go a week between charges.
ChrisAndroid
