how do fix my phone which is stuck in downloading mode+not conecting to pc
emanuel123
10
i was trying to install root (i had a recover) and the phone sudently it turned down and it says atthe start "phone si not running on android" or some thing like thath.Then bootloader is up and then downald mode is up
If i try to close it the same thing pops up again
Welcome to AC!
This Samsung A50?
Download Odin and frija firmware tool latest version from xda forums once download in Frija out your model number and csc to fetch the latest firmware then flash the stock firmware to return to normal
i did all of that but my7th and 8th numbers of my imie are 11 and i dont find the country whit the code 11
Romania youll have to try one of these CSC
CNX = ROMANIA
HAT = ROMANIA
ORO = ROMANIA
COA = ROMANIA
You put your model number in frija then the csc code and no firmware shows ?
Wait until it download to your computer then extract it with program like 7zip
Tfunz
