- Nov 12, 2012
- 23
- 0
- 0
Smart Lock Won't show Home and Work Toggles
I decided to try the Smart Lock feature post lollipop update and for a while it showed the home and work toggle switches. Now it just shows a home address that it gets from Maps and no work address. Both of these locations are set in maps and in Google Now. I also don't seem to be able to use the safe location function. I've cleared the cache partition and would hate to go through the factory reset process to try and fix it.
I use a pattern unlock and have an encrypted phone. Don't know if this helps at all.
