How do I get to Split Screen on my Pixel 3?
Sorry, I'm late getting back to this discussion. It's still not clear to me why you're not getting the App Overview/Recent Apps. When you tap the square button in the navigation bar, you should get the App Overview which shows you the recent apps that you've used (i.e., the ones that are open or cached in RAM). It's the screen where you can scroll horizontally to see screencaps of the apps that you've recently used.
In Android 11, it should look like this:
Thats what im trying to get to , hopefully you can guide little more then i can .
Yeah its safe , just choose not to share with others on that app
Ok mate so just use browser with links yeah or you mean don't share on app ?
{ EDITED }; ( Edited ) ; I'm a ***** All.undetstood with Imugur
In Browser has no settings or ability to add. Only scroll down or option to get app.
Short video with square Nav plus another SS of what I was trying to get to.
http://imgur.com/a/N8oWPQv
In that video, I can see the app icons for each of those screens at the top of each screen. That's what you need to tap to bring up the menu that has the Split Screen option. (Most of the icons were hidden by that big red screen recorder bar at the top, but when that bar goes away, you can see the app icon between the words "Most Viral" and "Following" -- I'm not sure what app that is.)
Look back at the screenshot I posted above -- you see the Google Home app icon at the top of that screen cap? That's where you should be looking for the icon, and that's where you have to tap.
Bahahhaha see completely me !! Yes I see now,Stupidly when looking just assumed it was a Header apart of the program not a setting & as you said recorder didn't help.
Cheez guys that was a long *** one for us hey ! So bloody simple,Can lead a horse to water but can't make it drink & that horse needed a drink.
B.diddy & Mustang your legends thanks for your patients & persisting with us especially for something like this.
Hey B.diddy I re read that most viral and following is just the App icons on selection in images app. Finally last vid,It minimises windows,gives you smoother access to apps in system & that split screen is cool. That it ?
http://imgur.com/a/icZ9CFZ
Glad that you found it! But I'm not quite sure what you're asking in your last post. In your last video, I noticed you got about halfway done with Split Screen, but didn't get it completely done. After selecting the first app for Split Screen, you'll see it temporarily occupy the top part of the screen. To select the second app for Split Screen, simply tap the next app's screen cap (NOT its app icon), and that will fill the lower half of the Split Screen.
Yeah I think I gottcha soz the misses needed us.
http://imgur.com/a/ImohKLW
This is what I get so no option for that unfortunately just the usual on app on screen.
It is easily done on a Pixel 4. But you're starting in the wrong place. Hit the white square at the bottom right of the screen. Then tap on an icon at the top of one of the app boxes. That's where you'll find the split screen selection.AC1.pngAC2.pngAC3.jpgAC4.png
Tap the square white button at the bottom right of the screen
Then tap (don't hold) the icon at the top or one of the recent apps.
You'll then get the menu with the Split Screen choice.
2009sxs
