How do I get to Split Screen on my Pixel 3?
Tap the square white button at the bottom right of the screen
Then tap (don't hold) the icon at the top or one of the recent apps.
You'll then get the menu with the Split Screen choice.
Think you might be in a earlier post,Link I sent to video beige your second last post here is same.
Will post SS now you can look.
I know this is not the correct subforum, but that technique works on my Pixel4XL. I didn't even know it had that capability. This is why I check all the Pixel subforums. Thanks…
Edison
ilech
