How do I stop my voice text from repeating everything twice?
  • Start date Start date
A
AC Question
Every time I voice text, my phone repeats the sentence or paragraph twice. Anyway to avoid this annoyance?
Re: How can I fix the "com.android.systemui has stopped" error?
This worked for me too. I wish I had read this before doing a factory reset 3 times!!!! Thank you very much.
Hi!
I had the same problem with my samsung s4 galaxy. I have solved it by going to the settings-aplication manager-google app (you have to disable it and uninstall it) after that I turn off and on my phone and i don't have trouble anymore.
I hope this will help😊
How to fix unfortunately com.android.systemui? Here to sloved the probelm :) . Go to setting find application manager > all > google apps then uninstall update > restart your phone. Then try press home keys then says you are welldone bye!
When I click to uninstall the Google app updates, it brings a message asking if I want to replace it with the factory version. Do I or don't I? Is unistalling the Google app updates going to affect using Google on any way on my phone (or affect anything else on my phone). Thanks.
Simply uninstalled the Google App update and worked straight away without even rebooting the phone (Galaxy S4 mini)
When I uninstalled the updates it just updated again later. You have to disable the app, once doing so then your phone will once again be yours! Thank you to whoever sorted this out! (if only 25 mins earlier so the lady love hadn't selected Maleficient to watch while I sorted out my issues... ugh)
You dont need to disable or uninstall the app. Just make sure you have automatic updates turned off , and then your apps wont update until you manually choose to
Thank you!Thank you! Thank you! This was driving me crazy.......not to mention draining my data , because I couldn't close my apps.
Go to your play store. Search for google quick search app. It will bring up a list and the one you have will say installed. Click on this and it will give you the option of uninstall.
Had the same problem since 1/21
I uninstalled the google app and everything went right back to normal!
THANK YOU!!!!!!!!!!!!!!!!!!!!
Followed the steps to uninstall Google's latest update and it fixed my S3!
Thank You!
Thank You!
Thank You All!:)
I had the same problem with my G3 beginning 1/20/17. Rather than uninstall the entire google quicksearch app (multicolored G icon) I just uninstalled the updates, restoring the original app (blue g icon) It seems to have fixed the problem. There may be some web sites that don't care for it and request an updated browser (weather.com). Perhaps they will fix this soon and we can resume using the updated version.
penguin_sam
