How do I stop my voice text from repeating everything twice?
  • Start date Start date
A
AC Question
Every time I voice text, my phone repeats the sentence or paragraph twice. Anyway to avoid this annoyance?
My just started a few days ago as well. Didn't do anything different...tried uninstalling any recent downloaded apps...still get error message
Thank you Sformoso!!!!
What a relief!
Re: How can I fix the "com.android.systemui has stopped" error?
I changed my battery to new one and that's when I got the error, haven't updated at all on my S3 and it's so old there are no updates. So I Uninstaller the Google apps updates few days ago and it did fix but I finally fixed mine by D/L firmware from XDA and used Odin to flash my system. It's not an update but some how system gets corrupt what my battery change did it don't know but I did find that it happened right afterwards ! My phone is rooted. And before I swapped battery I did a nadroid backup I did have trouble getting to CM system so it could have corrupted my sys. Doing a reinstall won't fix as Google does not install this section also my CM backup doesn't install F/W as part of the backup. If you don't know what I'm talking about don't use Odin as you can brick your phone. You could find out more at XDA it seems to be common error for YEARS. I hope the info helps you understand what happened and there is a fix maybe a dev will write a quick fix for all.
Quote Originally Posted by Gamekingx
I found out what caused it. Earlier today google pushed an update for their google quick search app ( https://forums.androidcentral.com/e.../store/apps/d...quicksearchbox&token=3NrfYOUq ), this update broke my home button.
So uninstall the app and you should be fine for now.
Thank you! You are a life saver. I never would have figured this out on my own. I will have to inform my ATT device support center in Austin, Texas. They were clueless! What are you searching with instead?
Google app update , you're such a genius Lizzie D
, you saved me from costly software reinstallation that would have never worked
It fixed the problem on my s4 mini, although I assume sometime the update is going to come through again and the same thing will happen.....
I removed the update and then I clicked the 3 dots menu on the top right in google play and unchecked the Auto-Update box.
I'm hoping that'll keep it from re-installing.
I hope Google fixes the app soon.
I removed updates but the problem returned when updates were re-installed after a few minutes. I have a S Note II.
any suggestions? will Google fix this?
I have the same problem . Go to settings goto google app . UUninstall update . I did this and it fixed the problem till a few minutes later Google updated it. Go figure I had to uninstall that up date too . How can someone get a message to Google to fix this ?
I tried this on my S4 mini
Settings/More/Applications manager/Google search/press Uninstall updates/Confirm.. Phone back to normal... 😊😊
wait...I thought the steps I quoted was actually the steps to uninstall updates for the google app; cause it looks like I only prevented my apps from auto-updating (the second thing to do), but didn't actually "uninstall updates for the google app" (the first thing to do). How do I: uninstall updates for the google app?
I talked to Samsung support regarding the issue with the error message when using home key after google app update. They are aware of the problem and support person said they have recieved many calls regarding this issue. They are advising customers to use the same work around procedures as described in other posts on this thread. The support peson also stated that a permenant fix would likely be put in place at some future date.
How do you uninstall it? I seem to only have the Google app, and my Samsung Galaxy 4 won't let me uninstall that. Thanks.
this fix totaly worked for me too! I just looked up the app in the playstore and then hit uninstall on my phone and everything went back to normal.
Thank you for taking the time to figure this out!
seems as though Google will update it every night so been uninstalling the update everyday so far. Pain in the butt so going to uninstall the entire app today. I'll keep my eye on this thread in ever fix it.
Guys just go to the play store and type"google" and uninstall that. It will work after that. At lest it worked for me.
I have galaxy 4 and i uninstall google from play store this morning. It works fine now. But i have google crome browser. You don't have to uninstall that.
thank you soo much i had the same issue, i cleard my cache in bootup menu , but it didnt work its been like that for 4 days now thank u doo much
Shawtiee
