How many people will only use the Finger Print Scanner on the S8+?
Who really uses this thing anyhow??
  • Total voters
I don't use my phone to pay. I use cc so I would use iris scanner if it is proven to be more secure than facial recognition. I prefer fingerprint in my V20 because I prefer where it is located. I wouldn't want to put fingerprints on the camera lens of my 8+ if I buy one
At this point I am waiting to see Note 8. Then I will decide. If note goes back to 16:9 I would definitely spend the extra $ even though I seldom use spen
Phone should have VOICE RECOGN4, this would be the ONLY unlocking technique I would consider using to unlock the phone.
Wait .. You said in the another thread you don't like AI but you are okay with your phone knowing your voice to unlock?
But with the retina you have to be looking at it exactly on point, which is the sole purpose of it but if you wear glasses you have to take them off from the video I watched. And I think it was on the Note 7 and since I wore glasses while reading and such I never pursued it.
You don't have to take your glasses off. You can use it at night as well. A few of my friends had the note7 and they wear glasses and used the iris scanner flawlessly.
It only prompts you to take off your glasses / contacts during enrollment. Once you get it set up, you can leave your glasses / contacts on to use the feature.
I plan on using the FPS clearly it will take a learning curve to use. But honestly people are blowing it way out of proportion.
I figure that I'll use the FPS less as I plan on making the iris scanner my primary.
Yea I am going to try out face scanning and see if I can spoof it. Really only friends or family could do that because most likely a stranger wouldn't have a picture of you.
I would love to use iris scanning for Sammy Pay, not sure if you have to use FPS.
Most likely I will end up use retina scan for everything.
I was initially worried about the placement of the fps. Since receiving my case I know where the fps will be and it's a very natural position for my hand size. Even more so then the middle back would be. So, i doubt most people will have any issues with it.
I used Samsung pay on my note7 and I think you could use the iris scanner, if I remember correctly.
sonmaria6
