How speed up my phone
joel567
19
I was just playing minecraft and the phone freezes for 2 seconds and works. but then after a while of playing it freezes completely and i had to restart it. Any suggestions. Lg g stylo. Play store
you have many apps open at the same time.. ??!! remember games are heavy files that runs on Ram memory, processor, even internet connection.. go to settings on the game and low the video resolution its a good start to try .. other thing to try is not to have the updates on auto, that will slow your phone on the background
Moved from the G4 forum to the More LG Phones forum, since you have a Stylo.
It sounds more like a problem with the Minecraft app, rather than your phone running slow. Did you install Minecraft from the Play Store or Amazon, or from some other source?
pns11
