- Dec 4, 2012
- 35,742
- 818
- 113
it appears, from what I've read so far, that AT&T has done everything it can to make it difficult to root.
I think that is more Samsung as opposed to AT&T.
If I understand correctly, it can be rooted with Towelroot, but not necessarily returned to stock at this time.
So long as the kernel was built before June 2014, Towelroot can be used on most devices. Once the device gets L, Towelroot is no longer an option.
I guess that wouldn't matter once the warranty period is past, though?
Correct. There is nothing wrong with staying stock through the initial warranty. If anything goes wrong, even with updates, it is either Samsung's or your carrier's fault.
Any other phones you can think of that would meet these specs?
The G3 Stylus version, maybe. Otherwise, no.
