How To CREATE & SHARE Your very own Splash1 Screen
Reformat your SD Card to FAT32 - Plug into your PC, copy everything off to your PC, then reformat your SD Card as FAT32, copy everything back. This is a common problem area.
Reactions: ssethv
did that. 3 times and still nothing. this will work no matter what ROM im using as long as i have rooted my phone correct?
Once you have it renamed PB31IMG.zip and on the root of sd card , and it reads a code real fast , then ask if you want to update .You do press up on the volume rocker arm up to update ? Then pressing volume rocker up again when ask to reboot ? :confused:
As far as I know it should work on any rom.
thats the thing, it doesnt ask to update, it says "parsing PB31IMG.zip" unless that means its asking to install. other than that i guess i will give it another go when i figure out exactly what im doing haha thanks for the help though. its just a matter of me wanting to try it again i suppose lol
Try taking .zip off the name of the file on your ROOT, just let it say PB31IMG. I had that problem before, let me know if that works
AmandaTaylor
