How to disable all battery notifications (Note4)
whmdan
7
I still own a note 4, primarily because I'm poor, but also because I enjoy it. I enjoy the interchangeable battery ability, something Samsung and Apple seem to be done with. I enjoy the 10,000 mah battery I use in place of the OEM battery. That said, I am sick and tired of battery notifications. I pretty much hate all notifications, especially the invasive ones like these. I'd like to never see another battery notification ever, least of all these new ones which ask if I want to turn off wifi and such. The answer will always be no. These more invasive battery messages started after I did a factory reset. Prior to the reset, I only recieved two notifications, which didn't ask about wifi or vibration. I'd prefer no notifications, but I'll settle just to ditch the newly added ones. I have tried various techniques found in other posts. I have linked screenshots to save people time. Please see the screenshots below: (the screenshots are to show the options I seem to be missing, which others have suggested to use)
L0n3N1nja
3,629
4
Are you getting a regular notification you need to dismiss from the notification panel or is it the pop up that appears on the screen about low battery? I still have my Note 4 at home, don't use it anymore but I can take a look at it later this week when I've got time and try to figure it out.
whmdan
7
Thank you for your reply and interest in helping me. It's two different pop-ups. Usually just one, but sometimes both. I'm linking screenshots. The top pop-up notification is the problem. The top one pops up nearly non-stop at times. It's very unpredictable. The other pop up is only at 15% and 5%. So I know when to expect it. I mainly want to be rid of the top one, but if I can disable both, that would be even better.
lilliejoylene
