Froalskiner#WN
- Jul 19, 2010
- 358
- 41
- 0
Ok how does one install the market place from a mac os preferably? It's extremely confusing and I am unfamiliar with command windows.
Thanks
All of the commands work on a Mac as well. As long as you have adb running properly you should be cool. Check the Rooting for Mac thread in the Fascinate thread
*paraphrased*
1.) Download the SDK from the above link and drag the contents to your Macintosh HD in finder.
2.) In Finder open up /android-sdk-mac_x86/tools, then extract the 4 files in the attached RAR to this folder.
3.) Open applications > go to Utilities > then open Terminal.
4.) Enlarge the Terminal window for easier viewing.
5.) If your Fascinate is plugged in to the Mac, unplug it now.
6.) On the Fascinate go to settings > applications > development and make sure USB debugging is checked.
7.) Plug the Fascinate into your Mac.
8.) From Terminal type the following (without the $ signs):
$ cd ..
$ cd ..
$ cd and*
$ cd tools
Then type in the same commands as in the first post except add a ./ to the front of adb so your commands would be
./adb devices
This checks the adb connection
