How to improve the battery life of my android phone?
Alon Solomon
Me Alon Solomon, is very much troubled about the battery life of my android phone.
Actually the problem have arisen after using the phone for 9 months usage.
The battery drains away very fastly which shouldn't be the case.Plz give suggestions regarding this..
Thanks,
Alon Solomon.
Welcome to Android Central! Which phone do you have?
First, review this guide: http://forums.androidcentral.com/ambassador-guides-tips-how-s/298919-guide-battery-saving-tips.html
Next, show us some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
1. The main Settings>Battery screen.
2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
3. The Screen category (to see total Screen On time).
4. The Cell Standby category, if present (to see Time Without Signal).
http://forums.androidcentral.com/am...ide-how-post-screenshots-android-central.html
Hi alon, you are right android phone battery life is low. If you want increase battery life so you use maximum mh power battery like 4000mh. i hope your battery life increase.
