[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
It is your lucky night -Success - got the resolution set - Here is a beta release - I still have to adjust the frame height a bit more and the frames/sec need some adjusting but this is better than the other and it installs where it is supposed to,- Totally flashable in CWM.
Enjoy guys.. Andipee2
Good work Jae works well. I dont know what you would want to fix
When you click on usb debugging, the pop up that appears is not an error. Just click on yes in that pop up and usb debugging will be enabled. Not sure why you are getting the message with screen reader. I looked up screen reader in the market and the first app that appeared was talkback which is a native app that will enable text to voice so you don't have to read texts while driving. It will turn your texts to voice so you can listen to your texts. It should already be on your phone, but if it's not, it is safe to download. How did you load the theme onto your sd card? Knowing how you did that would help to try and figure out where the file is.
Yeah I read that to on Screen reader just kinda through me for a loop as you said should already be on my phone Im not sure why its not. The accessibility thing I never saw before so that one worried me a little. So just hit yes and Im good ok cool thanks for that.
I downloaded the theme to my PC and just copied to my SD card. I didnt put it in a folder or anything just drag and drop. Should I have done something different?
Please forgive my ignorance I am learning as I go seems I learn best by trial and error (mostly error) this is all still new to me.
Figured out total user error. After I turned the US bugging back on I just started the process over just re-tracing my steps so to speak. I guess I didnt have the file loaded to the SD card somehow.
By bad :-[ But thanks for the help guys
Just want to say much thanks JaeKar99, Landshark, Sheepdog, DroidXcon,Adrynalyne, Gunnermike and EVERYONE else!!!! You guys are friggin awesome!!
With your help I (a complete an total techy tard) have rooted, froyoed, CWM'd and themed!!!!
Thanks for all you do, with out each of your infinite wisdom this would not have been possible.
Totally agree with you!! I was a "tech tard" too... These guys rock!!
Heads up nonvoodoo kernel hunters... jt1134 has a nonvoodoo kernel up..
Just released.. Link
Note: This kernel is NOT heavily tested.. early reports are that it runs well..
Please feedback if you try it.
Edit/Update: ComaVolt kernels updated..
Update - Update: LOTS of kernels being updated today
Reactions: bigjobber69
Can someone find out about JT's Non Voodoo kernel whats special about it what has he done? Like undervolt wise and such. Im not able to post overthere yet. Thanks guys and anyone who is testing either of these today pls post what ur getting, Im gonna flash when I get home from work! Hope good stuff with these. BTW im talking about the Non-Voodoo ones thanks guys as always your the best!!!
I'm on sc2.9.1 with VA Green & the android peeing on apple bootanim, thinking about going to sc 2.9.2 ..do I just wipe everything & flash the rom? or do I need to remove the bootanimation file 1st...trying to avoid a fc situation
Clear your Dalvik cache and your cache partition then flash SC 2.9.2.. No need to remove the bootanimation.. it will be overwritten with the ROM flash...
If you want to re-theme - wait until you have fully rebooted SC 2.9.2 then boot back into recovery to flash the theme.. if you flash ROM and them in the same session you will get a bootloop.
Reactions: sup3rchi3f
Does it have sound?
It does not have sound included.. As soon as we have a kernel that will play the sound I will rebuild the zip to include it...
Update: imnuts updated his kernels - If you choose to flash one... Please report back performance, features, or issues you find.
Thanks Jaekar for keeping the page up to date especially the kernels...i was just over at XDA looking for the latest imnuts kernel and the link was down but i came back over here and its up to date..thats just awesome your the man!
+1 Yeah me too I tried c/p links on his dropbox site to get the new imnuts kernel, no work...come over here and bam its all good....Jae has some powers alright
BTW i just flashed imnuts new -50 kernel and blutooth is not working tried standard voltage imnuts and same problem. Flashed infinitys comavolt and blutooth is back working again ( this is for voodoo btw). Will post over at XDA too to let him know.
Just tried to post over at XDA turns out i cant because i need more than 10 posts to post in that thread. Will anyone else with this problem please post and let him know....thanks :)
*chuckle* yeah had that prob when I joined xda...I posted 10 posts all over the place. Have a 10 minute pause between posts so no spam policy.
Thx for heads up...I never use bluetooth, but still, something not working is bad.
Oh and briguyy, I asked you a Q in the voodoo thread about your battery life.
Just had a look at imnuts xda thread...they got it squared ... imnuts is working on it
Looks like there are some 3G connectivity and bluetooth issues with several of the kernels that were released.. work continues..
Riyan75
