I know that imnuts was finishing up some new kernel tests and that he got the smartass governor working... so there is hope.
One of those little bits of info that Samsung does not share with many... I only figured it out after pulling bootanis apart and put them back together again..
The kernel will look for certain files in certain locations, in a prioritized order; upon boot.. data/local, then system/media...
It will also look for bootani.qmg (stock boot) first then it will look for bootanimation.zip second.. If your phone is set up with a kernel to look for this.... Now if you have both on your phone (in the same directory) - your phone will not know what to play first.. and will play them both at the same time.. overlapping boots.
If you have neither and the phone expects it you will get the 'Android' logo in landscape on your screed during boot...
Tasty bit for the day..
I have had no luck with installing the boot animations manually. I only have luck with the flashable boot animations. I tried the fix on the first post and deleted the .qmg and then installed the bootanimation.zip but i still get the android logo in landscape. What could i be doing wrong? I also restarted phone multiple times to see if would work but no luck.
I would guess that you are running a kernel that does not support bootanimation.zip files. If it was seeing the bootani.qmg file and not the bootanimation.zip file that is an indicator that the kernel is stock and will not seek the zip file.. The fact you had a bootani.qmg file is an indicator that you had a stock ROM of some kind and with that came the packaged stock kernel.
It is rather odd that you can get a flashed boot to run but not a manual transfer..
If you are not running a stock kernel then there is a misspelling or misplacement of a file or files.
Im running Sc 2.9.2 with ec10 kernal and ultimate honeycomb theme. So is it my setup or im just doing something wrong?
If you are running the EC10 kernel that came with SC 2.9.2 you should be able to swap out bootanimation.zip files in the system/media folder without any problems..
The only thing that I can think of that could be causing this to take place is the file manager you are using is not actually moving/copying the file from your sdcard to the the desired location. Make sure you have the read/write access enabled.. If you have that then you might consider..
I have seen a report (gunnermike53) had something like that happen and he had to completely reflash the base ROM to get boot animations to work for him.. That may be a last ditch option..
I will keep my eye out for something like this and if so garner a solution.
Until then there are plenty of flashable boots out there and there are lots that included in themes.
I am using root explorer and I do see it copy it but maybe it doesn't fully copy. There are some cool flashable boots but I really want the droid pissing on the apple haha
YAY!!!!!!!! I dont know what smartass govenor is. but if improves battery life and its NV im game
I want a flashable pissing droid too. I checked one a few wkns back didn't work. Maybe jae came across a new one. Wouldn't put it past him. Hes great like that.
So I followed the instructions for loading a theme (Nitro Dark Eclipse) For what ever reason nothing happened. I copied it to my SD card boot to recovery go through CWM back up, cleared cache partition and Davlik. Then I couldnt find the file anywhere?????
Now after I've rebooted my phone if I try to turn on USB debugging I get and error (No accessibility services). I check "Accessibility" and it says I do not have any applications and wants me to download screen reader from the market.
Any ideas what I did wrong? Could have sworn I followed the instructions step by step did I miss or mess up something? Should I download the screen reader and start over?
I believe I am running SC2.9.2 (it was one of DXC's all in ones that has sense been pulled from his thread) I have the new CW-all and EBO1.
As always thanks for the help.
Should I just wait and maybe youll find something better? i wont be home till tomorrow, I could just download it from my phone and flash it though i guess. If that works, let me know
Thanks buddy your the best. Keep me posted,
edit just flashed the one u posted and didnt work still had the purple honey comb, so the wait continues.
Yeahhhh I was afraid of that.. I will pull it down.. thanks for checking..
As soon as I get the other one to run correctly - I will post..
aight let me know, PM me and ill try it out for you if u want. plus knowing me ill miss it anyways.
