[How To][Links] Themes, ROMs, Kernels, Boot Animations: 9-16-11
Need help with overclock kernel
Alright, I have my phone how I like it....mostly
I'm looking to overclock it when I need to, and unclock it when I can as well. I'd like to be able to save battery life but have nice speeds too.
I've heard about the low voltage kernels, and I'm wondering what has been achieved with the fascinate?
Where do I find the kernel I want?
and the easiest way to go about flashing it? (I want to keep my rom and everything)
I'm working with:
Firmware 2.2.1
Baseband S:i500.04 V.EB01
Kernel 2.6.32.9
Build EB01
and a big thanks to everyone helping me get this far!
I'm working with:
Firmware 2.2.1
Kernel 2.6.32.9
Build EB01
Best bet is to spend some time in Jaekar's thread on Kernels.
http://forum.androidcentral.com/ver...t-animations-combined-resource-4-12-11-a.html
Download (Adrynalyne)EC01 Rom & (NemesisAll) Kernel-->OTB (TouchWiz CWM3 Voodoo OC adjustable) - Warning: Must read post for install and use! Go to Market and download Voltage Control. I set mine at 1120mhz and very stable battery last me 22hours.
Like Jmac9 said---->Best bet is to spend some time in Jaekar's thread on Kernels.
So, from what I'm seeing.. or not seeing rather, is that EB01 doesn't have an overclocked kernel?
Any advice on which kernel that's overclocked, would work with froyo?
Thanks.
Almost all (excluding the AOSP) kernels in the listed thread will work on the ROM build (EB01) you are running. Unless you have an AOSP construct and that will require that specific kernel..
Almost all are from the EC10 kernel source code release.. they will run on EB01 ROMS...
Got It Fixed!
After several frustrating hours of tweaking and tinkering with the controller file for boot animations I can now say I have figured about half of it out..
Thanks a bunch to davey11 for investing your time and patience in all the testing you did!
I have fixed a good portion of the original boots that I created (slowed the frame rates on some and sped up others.. and fixed the 'no loop' issues)..
I have also ported several very cool boots from the Epic threads.. There are some shutdowns on the way.
Please enjoy.
Please enjoy.
Great work! gears is awesome, I will be flashing and trying a bunch more right now! Awesome job,
Edit -might not be flashing anymore think i just found my fav one so far. Fuchia Boot is sweetness!
I don't get blown away much, but these helix boot anis BLOW ME AWAY.
Every one of them is totally killer.
Fascinate logo? Which one is that?
The 4 helix ones don't have a logo...just lloyd with a spinning thing underneath.
Its amazing! The file size scared me cause it was so small, but it is fantastic! Great Work!
Thanks.
My advice would be to stick with the undervolted kernels and stay away from the overclocked kernels. Myself, DroidXcon, JaeKar99, Sheepdog Elite, and I think also Kevin Gossett have given out advice numerous times to stay away from overclocking the Fascinate. Hell, even Gunnermike53 who does some of the craziest things to his phone just for the curiosity factor to see what will happen advises everyone to stay away from overclocking our phone. The people over at XDA who are overclocking their phones are for the most part highly advanced users.
Reactions: vi3tboiii54
criteriascenario
