How To Load Ringtones On Nexus 5 and quedtion on James Bond.
AndroidDario
227
How can I save a mp3 to be used as ringtone on N5?
Can I send and save a file directly? Can I set this file as ringtone? Do not laugh, I am coming from Apple, and I do not how to do that.
Last question: do you guys have a zip or rar file containing the ringtones from the Sony Xperia T Bond Edition? Can I use these files on an N5?
Thank you.
simply use or create a "Ringtones" folder on your "SD Card" and download the Ringtone files you wish to use and put them in that folder. do a soft reset and they should show up in your ringtone picker.
you can also use ASTRO file manager to manage the folders and files.
MIDI db
What if do not have SD? How can I do a soft reset?
Sent from my Vodafone 875 using AC Forums mobile app
Android devices all show an SD card, but there is a difference between the device SD card and the External SD card. The one he is talking about is the one the device has.
As for doing the soft reset, he is talking about just restarting the device.
The zedge app has a lot of ringtones, including Bond. All free
CassiveMock
