[How-To] Manual Rooting of LS670ZVH/ZVJ (+ links to root ZVD/ZV9)
Re: [How-To] Rooting LS670ZVH
I am sorry this after ZVH update, I guess I need to run the next steps 6) Root the ZVH Android to get back su access
Yes, as the previous poster mentioned, re-read Step #6 - Note 1.
So basically all you are doing is un-rooting then flashing the 2.3 then rooting again. because thats wat i did
Actually there is no need to un-root. You just need to put a particular recovery on the phone.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Patrick>c:
C:\Users\Patrick>cd \zvhroot
C:\zvhroot>install.bat
C:\zvhroot>adb push copy2sd /sdcard/
push: copy2sd/000root/Superuser.apk -> /sdcard/000root/Superuser.apk
failed to copy 'copy2sd/000root/Superuser.apk' to '/sdcard/000root/Superuser.apk
': Permission denied
C:\zvhroot>
i get this any help
C:\Users\Patrick>c:
C:\zvhroot>
i get this any help
Do you have sdcard in the phone and did you turn off USB mass storage mode?
i figured it out b4 now after ive done the ./rage it stays $ im not getting the # i did it 4 times
Try rebooting the phone and trying again.
In the past I've had to run rage 20-30 times with different timing of reconnecting to get the race condition to hit, but recently with the V9 recovery and ZVH it has always hit on the first try.
C:\Users\Patrick>c:
push: copy2sd/000root/su -> /sdcard/000root/su
push: copy2sd/000root/rage -> /sdcard/000root/rage
push: copy2sd/000root/install-unroot.sh -> /sdcard/000root/install-unroot.sh
push: copy2sd/000root/install-root.sh -> /sdcard/000root/install-root.sh
push: copy2sd/000root/flash_image -> /sdcard/000root/flash_image
push: copy2sd/000root/busybox -> /sdcard/000root/busybox
push: copy2sd/update.zip -> /sdcard/update.zip
8 files pushed. 0 files skipped.
3346 KB/s (21974068 bytes in 6.412s)
C:\zvhroot>adb reboot recovery
C:\zvhroot>adb shell
$ cd /sdcard/000root
cd /sdcard/000root
$ ./rage
./rage
[*] CVE-2010-EASY Android local root exploit (C) 2010 by 743C
[*] checking NPROC limit ...
[+] RLIMIT_NPROC={3372, 3372}
[*] Searching for adb ...
[+] Found adb as PID 62
[*] Spawning children. Dont type anything and wait for reset!
[*] If you like what we are doing you can send us PayPal money to
[*] 7-4-3-C@web.de so we can compensate time, effort and HW costs.
[*] If you are a company and feel like you profit from our work,
[*] we also accept donations > 1000 USD!
[*] adb connection will be reset. restart adb server on desktop and re-login.
cd /sdcard/000root
$ ./rage
./rage
[+] Found adb as PID 3454
thats what i get then usb debugging don't turn back on
is it possible to revert back to revert back to ZVD then root and put custom recovery then update it back and keep the root
No sir, If you do the ZVH update with a custom recovery, you will have a brick in your hand.
What do you mean "then usb debugging don't turn back on"?
Did you mean you can't connect to the phone using adb shell?
If so, I'm starting to think you have VD recovery instead of V9.
After the step install.bat I get "device not found".
mrtalha
