It is the same deal as linux. Just put all the files in your adb tools folder on mac and type the command in install.bat by hand. Alternatively copy the files *within* the copy2sd folder to the top-level directory of your sdcard (there should be no mention of "copy2sd" on your sdcard) Then just follow the rest of the instructions, skipping install.bat and substituting the appropriate directories for your installation.anyone able to use this method on a mac?
I know i was asking about linux earlier (work computer)... but i might have it figured out...
I was able to get to ZVH but now im stuck on the ./rage part. I cant seem to get the # to appear. I've ran ./rage multiple times but still nothing...
did u run the update.zip first? (small one showing up as an error 7 or whatever when u try to use it)
are you using V9 stock recovery or VD ?
yeah and i got the expected error
UPDATE
i just looked over the command prompt and im getting this message when i run install.bat (Step 6), "cannot open 'copy2sd/000root/rage' : no such file or directory. but it says 8 files pushed 0 files skipped. so i turned on usb storage to see the 000root file on my sd card and i see the rage file but it is 0 kbts
try and redownload and start over, turn off antivirus first, as some remove that or make it useless
check your pm box, also restart your computer
I don't have a Mac so don't want to say this will definitely work, but try this:/Users/bperfetti/Downloads/android-sdk-mac_x86/platform-tools/zvhroot/install.bat: line 1: adb: command not found
logout
[Process completed]
so the result should look like this/Users/bperfetti/Downloads/android-sdk-mac_x86/platform-tools/
Then from a shell prompt/Users/bperfetti/Downloads/android-sdk-mac_x86/platform-tools/copy2sd
cd /Users/bperfetti/Downloads/android-sdk-mac_x86/platform-tools/
adb push copy2sd /sdcard/
Just use xionia instructions. That doesnt put xionia on it. Eather they forgot the file or were just trying to remind you but idkHi All,
I have searched this thread but haven't found anyone having this issue. I have rooted my phone successfully but trying to install custom recovery and getting this error.
/system/bin/sh: Can't open install-xionia.sh
I did ls -l but i can't find the xionia.sh file any where. Can someone please help.
bobprobert I have same problem I get permission denied in terminal can u let me know how u fixed it thx
