[HOW-TO] Restore Nook Color to rooted stock
When I try writing the .img to the SD card I get an error saying not enough space on disk. I checked the properties of the SD card and it says I have 14.9 GB free. Its a 16GB disk and I have tried writing the 16GB .img and the 8GB.img Any ideas?
Re: Help--trying to restore Nook Color to stok
For dfishocc:
I had this problem too, multiple times while trying to re-install different versions of the Nook OS. What ended up resolving it was a factory reset. Make sure the Nook is off. Press and hold the Power and the N button simultaneously for seven seconds. It will boot to the Reading Forever page, then load a new page asking you if you want to do a factory reset. Hit Yes. Then confirm.
none of the links work need cwm boot for 16 gb card please anyone. need help badly
ellahayes
