[How-to] Revert to LS670V9, after installing OTA LS670VC/VD, using KP500 (Diag mode)
(4) Also, does this mean I will have to re-activate the phone? Any problems with this?
You will not need to *reactivate* your phone (ie change the MEID attached to your plan) You may or may not need to *reprovision* (ie have the critical info entered into your phone automatically so it works on Sprint's network) depending on how the process goes.
By provision I mean Hands Free Activation (followed by update prl, update firmware, update profile, etc.) pops up on your screen a few seconds and you are done.
Most of the time you won't need to reprovision either, but certain scenarios the provisioning data may get into an unusable state and you need to do a reset, which will force a reprovision.
OK, huge problem.
When I went to root my phone after following the instructions to revert to V9 (and losing my display,) my phone apparently got knocked out of USB debugging, because ADB can't find it and Android Screencast won't work.
How screwed am I here?
EDIT: OK, phone is on and making noise, so I'm in Android. Trying to get into settings to turn USB debugging on blindly, but I haven't had luck yet. Ideas?
EDIT 2: HALLELUJAH, I got ADB to see it again.
OK, huge problem.
How screwed am I here? I can't even tell if the phone's powered on.
You aren't screwed. Just stay calm.
You reverted to V9 successfully, that is good.
You can tell if your phone is powered if you plug it into the PC and hear USB sounds. Make sure you hear some sounds and at least you know the phone is working.
USB debugging doesn't get turned off by accident. Did you do anything to turn it off, either explicitly by the menus or by doing wipe data from recovery or privacy reset?
In windows, with the phone plugged in, look at the device manager
Start Menu->Run
devmgmt.msc
Look for something at the top that says ADB interface and under that "Android Sooner Single ADB Interface"
If that isn't there look under modems for "LGE Android USB Modem #x" and report if it is there (might need it for worse case scenario)
If you don't have Android Sooner Single ADB Interface, then USB debugging is truly disabled.
I wrote up how to turn on USB debugging blind here:
I forgot to mention in that post you need to slide/unlock the lock screen first, so do that before anything else.
http://forum.androidcentral.com/lg-...-software-version-ls670zvd-14.html#post724318
So what was the problem, was it USB debugging or something else?
Perhaps it'll help others.
Debugging was turned off somehow. I had a phone reboot I wasn't expecting during the KP500 flash that surprised me. Wonder if that had something to do with it.
The problem I have now is, I need to root my phone and I can't get z4root on it.
Your phone does reboot as part of KP500 flash. As long as the flash tool got to the "completed" stage, then that part worked ok. It is possible something got messed up with /data and it recreated everything from scratch, which would reset USB debugging.
Download z4root from here:
[APP] z4root - xda-developers
Turn on install from unknown sources.
adb install z4root.1.3.0.apk
from your PC.
for those with black screen issues after reverting to v9, and need to root, just use superoneclick 1.7. it will root the phone even with no display. then flash clock work recovery in cmd, then force flash vc or vd. i successfully rooted, flashed recovery, and updated on many devices using this method. using superoneclick eliminates the need to see anything on the device :)
Reactions: sfhub
Good suggestion.
I added SuperOneClick as a third option under the new LCD post.
You should also try android screencast. It really makes the screen issue a non-issue as far as rooting goes.
Reactions: kc720
09:19:01 : ******Extract Start LS670V9.cab*****
09:19:01 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
09:19:01 : ExtractInfo Error(0)
09:19:01 : Extract cab file error.
02/11/2011 03:08 PM 99,220,700 LS670ZV9.cab
5 File(s) 100,337,884 bytes
still having the same problem. my dir is identical
When you typed the name of the cab file into KP500 you used
LS670V9.cab
If your directory really did match what I gave you, then the filename should have been:
LS670ZV9.cab
Did your phone reboot yet? Post the log.
Don't reboot the phone if the process is hung and you see the updating screen on the phone.
Better to restart the flash process. When it can't see your phone, unplug/plug your phone in and hit restart. It should go into emergency mode.
yes it did.
21:51:58 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
21:51:58 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
21:51:58 : Start Date : 2011-03-21 21:51:58
21:51:58 : -------- Buyer Test mode ---------
21:51:58 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
21:51:58 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
21:51:58 : *****CheckOS Start********
21:51:58 : Microsoft_Windows_Vista Home Edition_
21:51:58 : *****CheckPCSyncPrograms Start*****
21:51:58 : PCSyncPrograms Not Found
21:51:58 : SetEmerModeAT()
21:51:58 : _IsConnectedPhone Call
21:52:04 : _IsConnectedPhone(1)
21:52:04 : 0 - NotConnected.
21:52:04 : 1 - Normal connect success
21:52:04 : 2 - Emergency connect success
21:52:26 : Checking the connection with the cell phone...
21:52:26 : dwWaitResetTime(40000 ms)
21:52:27 : Phone Mode(1)
21:52:27 : *****GetPhoneType Start*****
21:52:29 : Phone Type : CDMA
21:52:29 : *****Start GetPreviousStep*****
21:52:29 : _GetPreviousStep(dwStep:0x4)
21:52:29 : *****GetPhoneModel Start*****
21:52:31 : *****GetPhoneBinaryVersion Start*****
21:52:31 : Phone Bin Version : LS670ZVD_12
21:52:31 : *****Get ESN / IMEI / MEID Start*****
21:52:34 : ESN/IMEI/MEID : A0000028502193
21:52:34 : *****GetPhoneNumber Start*****
21:52:37 : Phone Number : A0000028502193
21:52:37 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : A0000028502193, Model :
21:52:40 : _GetAuthMark : wAuthMark(18598)
21:52:40 : Wait 3Sec
21:52:46 : _SetAuthMark Ok : wAuthMark(18598), PhoneMode(1)
21:52:46 : *****Start _GetBatteryLevel*****
21:52:48 : Battery(5)
21:52:53 : ResetPhone...
21:52:53 : Checking the connection with the cell phone...
21:52:53 : dwWaitResetTime(40000 ms)
21:53:23 : _IsConnectedPhone Call
21:53:29 : _IsConnectedPhone(1)
21:53:29 : 0 - NotConnected.
21:53:29 : 1 - Normal connect success
21:53:29 : 2 - Emergency connect success
21:53:29 : Phone Mode(1)
21:53:29 : m_dwBootWaitTime(35630)
21:53:29 : Checking the connection with the cell phone...
21:53:29 : dwWaitResetTime(30000 ms)
21:53:59 : _IsConnectedPhone Call
21:54:04 : _IsConnectedPhone(1)
21:54:04 : 0 - NotConnected.
21:54:04 : 1 - Normal connect success
21:54:04 : 2 - Emergency connect success
21:54:04 : Phone Mode(1)
21:54:04 : Call _ModeOffline()
yes it did.
So your phone is booted into Android right now? Look at the software version in settings->about phone.
If it says ZV9 you are probably ok.
However, your log file doesn't look like it wrote to the phone at all. In that case, I'd just start the process again.
If your phone isn't booted into Android and instead is in the Software Downloading screen, then do not restart the phone, only restart the flashing software.
You can press ctrl-c in the KP500 command prompt to get it to stop.
HELP! Just updated phone to LS670ZVD and I only have a MAC.
So I have been thinking about rooting my optimus S, because the low storage space warning is getting EXTREMELY annoying and I find myself having to constantly remove apps I want just to get rid of it.
Anyway, I've never read anything about rooting and then I come on here today because I can't put up with having that message one more time. And I see I apparently am screwed because I did the update the other day, not having read about the fact it would make my phone unrootable. I found directions showing that you can go backwards and the KP500, but my problem is I use a MAC and don't have bootcamp or anything that will run windows programs, so I'm really not sure how or even if it's possible to get my phone back to the previous version so that I can root my phone and also get my hotspot working.
Any thoughts or help would be greatly appreciated. Thanks
Download VirtualBox and install a copy of Windows on it.
Windows will run for 30 days without being activated, so you should have plenty of time to fix your phone.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Robert>cd c:\kp500-utils-en-v0.4.2
C:\KP500-Utils-EN-v0.4.2>ren LS670ZV9_20.S9_20.P60671.cab LS670ZV9.cab
C:\KP500-Utils-EN-v0.4.2>dir
Volume in drive C has no label.
Volume Serial Number is 18FB-9E40
Directory of C:\KP500-Utils-EN-v0.4.2
03/23/2011 10:05 PM <DIR> .
03/23/2011 10:05 PM <DIR> ..
03/03/2007 09:02 PM 344,064 fsum.exe
11/14/2008 01:56 PM 155,648 Inf_WebDnld.dll
08/18/2009 03:49 PM 424,960 KP500-Utils-EN.exe
08/03/2009 01:15 PM 86,016 LGMobileDL.dll
08/03/2009 01:15 PM 450,560 LGMUpgradeDL.dll
03/23/2011 10:04 PM 99,220,700 LS670ZV9.cab
02/11/2007 03:37 PM 22,133 ReadMe.txt
7 File(s) 100,704,081 bytes
2 Dir(s) 27,968,184,320 bytes free
C:\KP500-Utils-EN-v0.4.2>KP500-Utils-EN.exe
| ! LG-Utils V0.4.2 ! |
| KP500 |
| By Blackhorn for www.lgks360.e3b.org |
| NO WARANTY |
| USE AT YOUR OWN RISK |
Menu
A - Send ROOT partition on mobile phone
B - BACKUP ROOT partition on mobile phone
C - Send CUST partition on mobile phone
D - Backup CUST partition on mobile phone
E - Send USER partition on mobile phone
F - Backup USER partition on mobile phone
G - Extract CUST partition from .DFAT
H - Extract files from a WDB file
I - Extract files from a KDZ file
J - Flash with assistant (file .cab)
M - Extended /!\
N - Send STATIC_EEP partition on mobile phone
O - Backup STATIC_EEP partition on mobile phone
P - Unlock /!\
Q - Exit
Choice: j
Phone Model (Ex: KP500): ls670
File (.CAB) including the firmware (Ex: C:\V10G_04.cab): ls670zv9.cab
Version(SW version) (Ex: V10G_04): ls670zv9_20
Send the arguments...
Loading...
Log from the updater below
21:56:04 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
21:56:04 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
21:56:04 : Start Date : 2011-03-23 21:56:04
21:56:04 : -------- Buyer Test mode ---------
21:56:04 : [C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone] ???丮 ???? ?õ?
21:56:04 : RemoveDirectory1 Error(2):C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\Phone
21:56:04 : *****CheckOS Start********
21:56:04 : Microsoft_Windows_XP_Home Edition_
21:56:04 : *****CheckPCSyncPrograms Start*****
21:56:04 : PCSyncPrograms Not Found
21:56:04 : SetEmerModeAT()
21:56:04 : _IsConnectedPhone Call
21:56:04 : _IsConnectedPhone(0)
21:56:04 : 0 - NotConnected.
21:56:04 : 1 - Normal connect success
21:56:04 : 2 - Emergency connect success
21:56:07 : Checking the connection with the cell phone...
21:56:07 : dwWaitResetTime(40000 ms)
21:56:08 : _IsConnectedPhone Call
21:56:08 : _IsConnectedPhone(0)
21:56:08 : 0 - NotConnected.
21:56:08 : 1 - Normal connect success
21:56:08 : 2 - Emergency connect success
21:56:09 : _IsConnectedPhone Call
21:56:09 : _IsConnectedPhone(0)
21:56:09 : 0 - NotConnected.
21:56:09 : 1 - Normal connect success
21:56:09 : 2 - Emergency connect success
21:56:10 : _IsConnectedPhone Call
21:56:10 : _IsConnectedPhone(0)
21:56:10 : 0 - NotConnected.
21:56:10 : 1 - Normal connect success
21:56:10 : 2 - Emergency connect success
21:56:10 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
21:56:40 : _IsConnectedPhone Call
21:56:40 : _IsConnectedPhone(0)
21:56:40 : 0 - NotConnected.
21:56:40 : 1 - Normal connect success
21:56:40 : 2 - Emergency connect success
21:56:40 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
21:56:43 : _IsConnectedPhone Call
21:56:43 : _IsConnectedPhone(0)
21:56:43 : 0 - NotConnected.
21:56:43 : 1 - Normal connect success
21:56:43 : 2 - Emergency connect success
21:56:43 : [009,400,102,102,102]The USB cable and your cellphone are not connected.\nPlease connect your phone and wait for connecting \nthe USB port for a while and press the [009,700,147,062,092]'Restart'[009,400,102,102,102] button.
21:59:54 : Check Cancel button active..
21:59:54 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
21:59:54 : Page_Error ?κ??Դϴ?
21:59:54 : [011,700,147,062,092]LG Mobile Phone Software Update was canceled\n\n[009,400,102,102,102]To quit LG Mobile Phone Software Update, please press the [009,700,147,062,092]Exit[009,400,102,102,102] button below.
21:59:54 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
*I am able to get to the lg update step but no matter what I do it refuses to read the phone. It is connected it just won't read it for some reason. I already had my phone flashed but I accidently reset it to factory settings so I'm trying to reflash it and it just isn't cooperating. Any help would be GREATLY appreciated.*
Did you make sure USB debugging is enabled?
Does the phone or PC make any sounds when you plug in the phone?
Under start menu->run
devmgmt.msc
Do you see anything listed under Modems that looks like Android USB modem?
sfhub - THANK YOU!!!
Thank you for taking the time to share this with us. I lost my Hot Spot with the VD upate (last time I trust sprintusers.com to warn me about an update). I clicked the Thank You in your signature, but thought I would post one as well. Your time and energy are very much appreciated.
devmgmt.msc
Yes it beeps at me when it's unplugged and plugged in. And yes USB debugging is enabled. And yes LGE android platform usb modem is under modems.
Welladjusted
