[How-To] Root LG Optimus T
Help
Right after ./rageagainstthecage
wait 2 minutes, both the USB on the computer & on the phone seems to have been reconnected...
try the next step of adb shell and I get an error that "no device found"
Any assistance would be helpful
How do I get the attached file? Will this work on the T-Mobile LG Optimus T. And why can't I find z4root in the android market?
Can't get the ADK to install so I can begin rooting my phone. It complains that I do not have the Java SDK installed. I tried installing the JRE-6, then I tried the JDK-6, and JDK-7 installations. None of them worked. If it helps, I have windows 7 64-bit.
Any suggestions?
Any suggestions?
Figured it out, had to install the 32-bit version. But now I have a new problem. When I perform step 4, it never reconnects. when I try to begin step 4 over, it says my phone is not connected. I had to reboot my phone, then I could execute adb shell. When I try to issue it any commands in step 4 either starting over, or continuing where I left off, I get a message of permission denied in the command window. It's like my phone is not allowing me to write to it anymore.
Doris King
