How to Root
Status
Not open for further replies.
ok i followed the process but nothing happens i get the same thing over and over again is there something i am missing? i restarted my phone after setting debuggin on. start root thing is that engaged on pc or phone? can i have a screen shot or copy/paste of a succesful log of how its supposed to look on command prompt
sry for being a nub very new at this
Yeah this is my first time as well. It looks like you haven't installed the drivers. Download them, unpack them, then run setup.exe. You should be good after that I think.
Make sure you've unpacked the FascinateRoot_v02.zip and THEN run the start_root.bat
well i got abd or w.e its called to get going but it keeps stating that device is not found....(after it reboots my phone) help meh purdy please
edit* i have everything installed drivers and such. idk what to do with this : /
i have a really stupid question, sorry im a noob. but when downloading the drivers, and the .zip files, you download them on a pc or on the phone?
Dizzy that is a perfectly valid question. the only stupid question there is , is the one you don't ask
Download to your PC
hi. I am new to this and very confused. I have tried many methods of tethering my fascinate but none have worked. So I am trying to root my phone now and I have followed your instructions but it still does not work. It says my phone is not rooted and there is a missing kernal file or something...help?
Did you download and install the drivers before starting, you can find them on the first page, if you are using a basic home pc its probably this file which you can find on the first page of this thread looks like this below
(this is not a link, go to the first page to download it)
http://www.wikifilez.com/root file...Phones_x86.exe
im wondering, i have a telus fascinate running froyo 2.2 stock. Can i use this method to root? Also, can anyone recommend what roms to use or anything to improve battery life... i cant seem to get more then 9 hours or so... :(
**EDIT** nevermind, i went ahead and tried it and it worked like a charm! thanks for the awesome instructions!
Not workin for me....fascinatr root
Ok I did all u said. Mine says error device not found like five times. It turns phone off and on I unlock and wait........after five min I hit a key and nothing. Drivers r install debuggin enabled.....plz help lol
* Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
* Testing if your device is connected
'adb' is not recognized as an internal or external command,
operable program or batch file.
* If you are NOT connected please follow these directions
* Install the correct drivers
* Turn On Debugging
* Check usb port, cable and phone
* Then rerun this application
Press any key to continue . . .
* Pushing the files to your phone
* rage.bin, busybox, Superuser.apk, su, com.sh
'PMSLEEP' is not recognized as an internal or external command,
* Restarting your phone to ensure the exploit will work
* When your phone comes back on please unlock it if it is locked and then
* wait
* About to exploit your device
* This will take about 3 minutes
* If it doesn't respond after waiting 5 minutes then it probably failed,
* so you should close this and run again
* Start Time: 10:53:06.32
'rage' is not recognized as an internal or external command,
** Successfully exploited, installing permanent root files and deleting temp fil
es
* Restarting your phone now.
* Complete
idk what to i keep gettin this message
Run START_ROOT.bat as a normal user, not administrator...
I have the exact same problem as fastavanti, still looking for an answer...
I am trying to root but when I do it says its loaded with a trojan and my antivirus will not let it download. What do i do??????
I finished rooting it I think I mean the program ran in the command prompt and it did restart my phone but when I downloaded ROM manager it says it can not find superuser /system.bin.su or /system/xbin/su
same problem here... I'm lost
This is how my bat file ran:
* daemon not running. starting it now *
* daemon started successfully *
List of devices attached
I500ac61da82 device
* Turn On Debugging
291 KB/s (1867568 bytes in 6.265s)
102 KB/s (26264 bytes in 0.249s)
510 KB/s (196521 bytes in 0.376s)
23 KB/s (5392 bytes in 0.224s)
8 KB/s (281 bytes in 0.033s)
* wait
* Start Time: 2:12:58.19
error: device not found
es
* Complete
Thanks for the reply... yes to all of the above.
I found a solution, and it should work for the few others here I saw with the same issue.
My phone was still in the shutting down mode when the .bat tried to continue, so though I've never created a .bat, I was able to read this one, and "fix" it.
First off, it seems the "call PMSleep" was not working. Then I noticed where I had to "press any key to continue" there was a "pause" in the .bat, so I added a couple of pauses, though I'm not sure the second one was needed.
When the phone shut off, I waited for it to come back on, unlocked it, waited another ten seconds for good measure, then continued. For doubly good measure, I added a second pause where it called for a 3 minute wait.
FYI - Windows 7 64 bit
So for those whose process was running exactly like mine (2 post up), right click on the START_ROOT.bat, and click edit, then add in the couple changes I made (nothing that adds any risk, just two pauses):
@echo off
adb kill-server
cls
echo ******************************************************************************
echo * *
echo * Dirrk's EZ Root v0.2 (Sebastien Krahmers Exploit) *
echo * *
echo *
echo * Testing if your device is connected
echo *
adb devices
echo *
echo * If you are NOT connected please follow these directions
echo * Install the correct drivers
echo * Turn On Debugging
echo * Check usb port, cable and phone
echo * Then rerun this application
echo *
pause
echo *
echo * Pushing the files to your phone
echo * rage.bin, busybox, Superuser.apk, su, com.sh
adb push busybox /data/local/tmp/busybox
adb push su /data/local/tmp/su
adb push Superuser.apk /data/local/tmp/Superuser.apk
adb push rage.bin /data/local/tmp/rage.bin
adb push com.sh /data/local/tmp/com.sh
adb shell chmod 0755 /data/local/tmp/rage.bin
call PMSLEEP 2
echo * Restarting your phone to ensure the exploit will work
echo * When your phone comes back on please unlock it if it is locked and then
echo * press any key to continue
adb reboot
call PMSLEEP 60
pause
echo * About to exploit your device
echo * This will take about 3 minutes
echo *
echo * If it doesn't respond after waiting 5 minutes then it probably failed,
echo * so you should close this and run again
echo *
echo * Start Time: %TIME%
echo * Wait 3 minutes, then press any key to continue
call rage >NUL
call PMSLEEP 180
pause
echo *
echo ** Successfully exploited, installing permanent root files and deleting temp files
echo *
adb shell sh /data/local/tmp/com.sh
call PMSLEEP 4
adb shell rm /data/local/tmp/su
call PMSLEEP 1
adb shell rm /data/local/tmp/Superuser.apk
call PMSLEEP 1
adb shell rm /data/local/tmp/busybox
call PMSLEEP 1
adb shell rm /data/local/tmp/rage.bin
call PMSLEEP 1
adb shell rm /data/local/tmp/com.sh
call PMSLEEP 2
echo *
echo * Restarting your phone now.
echo *
adb reboot
echo * Complete
echo *
pause
I appreciate your update, EdwardsNH. Unfortunately, it didn't work for me and the phone kept freezing. I ended up using the z4root method from XDA, downloading it from the forum via Astro File manager (change the preferences to allow browser downloads, then go to the file to install). Worked like a charm. Everyone at this forum is super helpful, though! Learned a lot.
root problems
hi i was trying to root the fascinate and i have completed all the steps correctly i downloaded the correct drivers, then i hooked the phone up with debugging turned on and also stay awake. i connected it to the pc and the drivers installed correctly but when i execute the root it goes through and pushes the programs but then the cmd window closes out really fast and nothing else happens i captured a screen shot of it right as it closes and there is an error that reads
'find' is not recognized as an internal or external command operable program or batch file.
i have tried it with the sd card mounted and dismounted. i am currently running windows 7 64bit and my phone is 2.1-update 1 build number sch-i1500.di01 please any information will be usefull and im and i like to tip the developers that help me out lol
need help
i have downloaded the root file but when i try to uncompress it i get a message that it contacting a trojan will some one give me a correct link plz
Status
sakhe
