How to Root
Status
Not open for further replies.
Ok so i have spent 5 hours trying to achieve root with i ended up having to mix and match methods. i can't say this will work for you and dont ask me what any of it means it works and thats all i care about.
As always do this at your own risk i am not responsible for anything you do to your device
1. From OP of this thread download and install the the appropriate Samsung Fascinate drivers
2. Plug in your Device, put it in debug mode and stay awake
3. From OP of this thread download the FascinateRoot_v02.zip file and extract it to the root of your C:\ drive So the path should look like this: C:\FascinateRoot_v02
4. Now go to your start button on your menu bar,in the run field or search field depending on your version of windows, type CMD and hit enter. The command box will present itself. From here on out just copy and paste the commands i will provide below. To paste in the command box you must right click on the mouse and select paste. Do not paste BOLD text below those are just for info.
Commands are as follows:
cd C:\FascinateRoot_v02
adb devices
It will state
"List of devices attached
I500******* device"
If you dont see this you are not connected
adb shell
You should now be at a prompt with a $
adb push rage.bin /data/local/tmp/rage.bin
cd /data/local/tmp
chmod 0755 rage.bin
This step is important. After you type the next command there will be a pause and you will have to wait until you are kicked out of adb shell. It is important you do not touch your phone or type anything in the command window. If you do don't worry, nothing bad will happen you will most likely have to pull your battery and try to run the command again. If your phone doesn't lock up you can probably unplug it and plug it back in and start back at "adb shell"
./rage.bin
After several seconds the $ prompt will come back
After another 20 seconds or so you will be kicked back to the C:\FascinateRoot_v02 prompt.
adb devices
If your device is still connected proceed
adb shell
You should now be at a # prompt
This mean you have achieved temporary root on the device.
exit
You should now be at the C:\rootfiles prompt again
Type the following commands:
adb push su /sdcard/su
adb push busybox /sdcard/busybox
adb shell
mount -t rfs -o remount,rw /dev/block/stl9 /system
cd /system/xbin
cat /sdcard/su > ./su
cat /sdcard/busybox > ./busybox
chmod 4755 su
chmod 4755 busybox
exit
You should be back at the C:\FascinateRoot_v02 prompt
adb install Superuser.apk
It will now install the Superuser.apk this may take some time while it installs when it is over it will say:
Success-after you see Success hit Ctrl-C Then reset your device
5. You have now achieved Root, congrats. If this didnt work for you well then :confused: time for a different approach.
Here is a screen shot of what i did, you will see some mistakes i made... and at the end it says failure but i had already manually installed the Superuser.apk so thats the reason for that. this is just to give you an Idea of what you are getting yourself involved with.
GOOD LUCK!!!!
Anyone having luck with this, yet? I cannot get root after DL09 update either
Anyone having issues already start loading apps etc on their phone?
Dont know if that makes any difference but could be a possibility.
Rooted first try!! I followed the steps exactly, one click and 5 min, I'm rooted!! Thanks for the work guys!
Started with DL09 so it can be done with One Click.
I want to root my phone. Do I need to back everything up before I root it or not? Is there a good app for this?
Rooting will not destroy your apps. Your phone will look exactly the same. Rooting just allows you to have superuser rights, which means you can modify your phone any which way you like (including getting in serious trouble). VZW wants you to use the phone THEIR way, with root, you get to use it YOUR way.
So, following the manual steps, rage.bin runs but hangs at the $ prompt. It has been over a half hour. That seems to be my largest hiccup. Any ideas?
EDIT: Took about 50 minutes, but it went through and all rooted.
and do i use the 32 bit or 64 bit and this root is good for the new dl09 update,and thats all i have to do,what about roms and all that jive.?or is that it?lol sorry ive never rooted.
to find out what your computer is, go to start from the taskbar on your computer right click on either "computer" or "my computer" depending on what windows you are running and select properties it will tell you if you are 32 or 64 bit like so
this should work for DL09 other people have had success with it...and lets worry about rooting then you can move on to roms
when i download the files i will save them correct,not open them?then how do extract them?sorry i may sound stupid but not farmiliar at all
windows 2000 profesional.lol i may have to do all this at parents house they have a updated window computer and i can install my device on it.my work computer is saying i dont have permission to hook my phone up on here.so ill start over.i look and see what bit parents computer is then i will download that file,then what
if you are talking about fascinatev02.zip file , save it then go open it and extract it to your c:\ drive
after its extracted, with your phone in debug mode and plugged in ,
go open the folder and Hit start root
okay how do extract it
just double click the zip file and chances are winzip will pop open , it will most likely be a trial version so a popup will come up asking you to purchase just hit close, and from there there will be a menu at the top look for the words "extract to "
It says download not supported on this phone.I have to hook it up to the computer
i must still have to access it thru computer to get that file on my phone cause it says file not supported on this device
Status
visionarysearchist
