[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
why isn't this thread in the "Sprint Optimus guide to Rooting, ROMs, Recoveries & Themes" sticky?
It was, it was replaced with the ZVH rooting thread.
sent from my CM7/Reborn w/ 1 Gb internal storage Optimus S
Always happy to help, hit that thanks button if I did
Re: [How-To] Rooting LS670ZVD with GingerBreak (no reverting and
I think it deserves to be there (with the same logic the ZVD roms should be taken out as well). But let's face it, ZVH update is full of bugs and I don't think it's worth the trouble. I mean, what's the advantage of having it anyways? Coming back to zvd for the second time, I now hope that devs (drew, ath3nos et al.) will continue the development of CM7 on zvd radio. I am back to reborn now and it feels faster than the gROM at 748 (and I am confident that my gmail will sync and the screen will not go crazy). Not to mention about the battery life...
Sounds like off topic, but this rant summarizes the reasons why imo this easy method of ZVD rooting should be easily accessible and not defunct.
edit: This post is not meant to sound disrespectful to the devs working on the stock GB mainframe. I appreciate your courage and efforts on trying to clean up the mess that LG/Sprint gave us.
For your future reference, it is easily accessible from the first few lines of the ZVH rooting thread. All rooting methods for previous ROMs (ZV8, ZV9, ZVC, ZVD) are specified there.
Reactions: memsman
aloha all,
so i need some help, i figured out due to your guys help that the reason i was getting "permission denied" during step 3 for the zvh flash process is because i did not root to zvd first! now i am using gingerbreak to root my LS670ZVH to zvd and everything seems to run smooth until step 8. both commands in step 8 work for me (atleast run gingerbreak) but i dont know why it does not seem to work afterwords. what happens is this: cmd completes the process basically as soon as i type it (with the last line being: vold: 1380 GOT start: 0x00014354 GOT end: 0x00014394) i have no way of really knowing if it completed the process in full, because from what i read it should take several minutes but mine finishes in several seconds?? then after that process, the cursor is left blank (meaning with no symbol in front of it) and anything i type like any of the following steps just seem to repeat exactly what i typed in. so steps 9 - 13 just repeats whatever i typed in. This also happens in steps 3-7 but seems to work because in step 4 i can push the data over and i can run gingerbreak in step 8. i do not know why it is not working after step 8, my phone seems to be normal and nothing happens even at step 13 when i type exit? any help is greatly appreciate!!
Starting from Step 9 all of the commands I type copy themselves. Did I do something wrong?
+ A few million to the OP. Thanks, Drew!
It doesn't work. What am I doing wrong? I downloaded everything and then when I open the app to root, it takes just a few seconds, then it says my phone has been rooted, but nothing happens. No reboot, no warning, still the same.
how in the world do i start up adb shell :mad: .... I used gingerbread to one click root my phone and now i am in the proccess of backing it up and i have no clue how to run adb shell!!
Reactions: eracet
ya know isn't there a freaking one click drive by download for this i mean downloading everything on the internet to root a phone!!?? wth?? any way isn't there an easier way if so email me at no spam either if i find spam i will continuously report u till ur acc is disabled im in a bad mood need a root and haven't had MY COFFEE!!!!!!!!!
i rlly need a root and am getting no where youd be my hero just to give me a working link with no sposors filled with trojans and malware please do not replyto me on here email me thank you!
I used gingersnap... if you have windows 7 its a snap, no pun intended, the tricky part is to plug in your fun click on usb debugging then click on it again to enable i have no clue why this works but i guess windows just doesn't like android.... but the only thing you have to download is the driver software for the phone and gingersnap, of course.
Ok I am running and running threw all these steps over and over again and none of them are working,I have the optimus S with android firmware of 2.3.3 I would like to root my phone but nothing is working, little help please??
How long is a "few minutes" for step 9 (./gingerbreak)? I have given it almost 25-30 min and I still dont get the # prompt back. All drivers were installed, and I can get through steps 1 - 8 easily.
I also don't have a SD card in the phone. Is that required for the rooting process?
I am having the same problem. The last thing I get back is: "[*] cold: 0065 GOT start: 0x000142a8 GOT end: 0x000142e8". After an hour of no activity I had to use <ctrl><break> to exit.
Am I missing something? Thanks for any help as I am out of ideas to try.
At the top of the rooting section is an automated root method i would recommend. It says it is for zvh, but will also root zvd basebands. Kinda takes all the guess work out of it.
Thank you for the suggestion. Worked like a charm. Never thought to use it since it said zvh.
it tells me the file doesnt exist when i try installing gingerbreak, and then when i go to see the file its gone. WTH?
I just installed adobe flash 11.0 on my optimus s670 without any of the above instructions. But....the link to adobe settings is not working any suggestions?
this thread is about rooting your phone (and is actually also somewhat obsolete). For questions regarding adobe flash player please go to this thread.
IM totallly having some serious issues trying to do any of this for my lg optimus i cant seem to get gingersnap to work or any of the other ones... i even tried to push as well as have all the files downloaded. i really want to enjoy a moded phone but this is making it impossible.... PM ME please.
pramanj96
