[How-To] Rooting LS670ZVD with GingerBreak (no reverting and OTA works too!)
Re: [How-To] Rooting LS670ZVD with GingerBreak (no reverting and
IM totallly having some serious issues trying to do any of this for my lg optimus i cant seem to get gingersnap to work or any of the other ones... i even tried to push as well as have all the files downloaded. i really want to enjoy a moded phone but this is making it impossible.... PM ME please.
Try gingerbreak v1.20 by chainfire worked for me :D:D
http://www.google.com/url?sa=t&rct=...hF4RaCstsUhhEjNqQ&sig2=HpNelyhuqgI9nU2sMhG4XQ
Just to start out, I know never i mean NEVER do an OTA update but... my wife didn't want me to root her phone but reciently she changed her mind. I guess within the last 4 days there was an OTA update that makes this method null and void.... i have tried alot of diffrent methods to get around this update but as of yet no luck... when trying to move su over to the systems folder i received and error that said the file / directory didn't exist... but i was trying to create it. Then i mounted the systems folder with the "mount -o remount,rw /dev/block/mtdblock5 /system" it allowed me to move the su file and i then chmod'd it ... on restart it still didnt work ... i will keep everone updated on where i am at on breaking the new OTA but any help otherwise would be very much helpfull....
Thanks Again,
DJDeath
Thanks Again,
DJDeath
Assuming you are running on either the zvd or zvh baseband, use this method. It will also install xionia recovery.
http://forums.androidcentral.com/showthread.php?p=1381615
that didn't work ... it was unsucceessfull on all the pushing of su and busybox to the system folder also failed the chmod.... so i more on word ....
also if it helps any the baseband on the phone is lg670WVD_60401001
enable the scroll buffer in the main menu, then post the log and I will be able to tell you what is going wrong.
EDIT: I used adb push to push su and busybox to system partition
I am trying to root but keep getting stuck at:
[**] Gingerbreak/Honeybomb -- android 2.[2,3], 3.0 softbreak
[**] (C) 2010-2011 The Android Exploid Crew. All rights reserved.
[**] Kudos to jenzi, the #brownpants-party, the Open Source folks,
[**] Zynamics for ARM skills and Onkel Budi
[**] donate to 7-4-3-C@web.de if you like
[**] Exploit may take a while!
[+] Detected Froyo!
[+] Found system: 0xafd14129 strcmp: 0xafd1cb9d
[+] Found PT_DYNAMIC of size 264 (33 entries)
[+] Found GOT: 0x000142a8
[+] Using device /devices/platform/goldfish_mmc.0
[*] vold: 0065 GOT start: 0x000142a8 GOT end: 0x000142e8
It's been like this for an hour now....:confused::'(
[+] Detected Froyo!
Same exact thing happened to me, I followed directions exactly
Are you trying to root ZVD or ZVJ with this? It doesn't work on ZVJ.
Could you possibly link a method to root ZVJ? One that's confirmed to work as of recently, I've noticed some of these threads are somewhat old which makes me a little bit reluctant...
This one?;
Android Forums at AndroidCentral.com > Sprint Optimus S > LG Optimus S Rooting, ROMs, and Hacks > [How-To] Manual Rooting of LS670ZVH/ZVJ (+ links to root ZVD/ZV9)
My apologies, I was looking for a 100% manual method and was confusing myself in the process-thanks.
Gingerbread executes but never returns to command prompt #
last line is
[*]vold: 1213 GOT start: 0x00014370 GOT end: 0x000143b0
and blinking cursor
Please help
last line is
and blinking cursor
Please help
Did you type 'su' at that $ command prompt?
Please post the command you entered and the output in full.
no but my command prompt was # not $. I tried with su
C:\android\platform-tools>adb shell
# su
# cd /data/local/tmp
# ./gingerbreak
[+] Plain Gingerbread mode!
[+] Found system: 0xafd18495 strcmp: 0xafd0d570
[+] Found PT_DYNAMIC of size 232 (29 entries)
[+] Found GOT: 0x00014370
[*] vold: 16022 GOT start: 0x00014370 GOT end: 0x000143b0
I realized that with # I was su. So I just used USB copy to copy flash and img. Worked fine and successfully installed ROM
pramanj96
