W1LL1am.A.W333z3L
- Feb 26, 2012
- 2
- 0
- 1
Re: [How-To] Rooting LS670ZVD/ZVH (100% automated) + ZVJ (automat
I'm completely new to rooting phones, so forgive me if questions seem obvious. I don't have MS Windows, and don't understand the Linux / Mac directions in Reference Section B. Section B says you have to
Nevertheless, the Note 1 instructions in Section B say to
Maybe that's enough questions for now. If someone can answer these, I may be able to take it from there. Thanks in advance.
Does this mean copy all the files in optiauto.zip onto the phone's SD card?Install the rooting files to the phone
Is adb a program that runs on the PC and allows you to run shell commands on the phone by typing on the PC? It appears to be, because optiauto.zip contains a file adb.exe, i.e., a Windows executable. If so, then you can't run adb on Linux or Mac.and start adb shell
[Is this "adb tools" a directory in the phone, or in the PC?]Unzip the package to your adb tools directory
This completely confuses me, because we are not using MS Windows, but we still are supposed to be using adb., then you can substitute with:
adb push copy2tmp /data/local/tmp/
adb push copy2sd /sdcard/
adb push copy2sd-img /sdcard/
adb shell
