N norack New member May 22, 2015 2 0 0 May 22, 2015 #1 Dear All, I just upgrade my Note 3 to Lolipop but I got problem : - Battery drain fast - Some application slower to open How to fix this problems. Thank You
B. Diddy Senior Ambassador Moderator Mar 9, 2012 169,809 11,238 113 May 22, 2015 #2 Welcome to Android Central! Was this an official over-the-air update, or did you manually install it? Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-11017
N norack New member May 22, 2015 2 0 0 Sep 23, 2015 #3 I use official over-the-air update to update my Note 3
T thailen Member Oct 9, 2012 16 0 0 Dec 11, 2015 #4 Sorry to bother you, but if you can't advise me how to upgrade from Android 4.3(on my Galaxy Note 3), where can I get upgrade advice?
