How to Stream Hulu on the Nook Color and Other Android Devices
Tried it on my G2x, EB1.0.4Froyo ROM. Says "Hulu requires Flash Player 10.0.32 or higher..."
I get the same error!
This definitely didn't work but I do love that browser now. Hahahah... When I go to hulu.com is states "Hulu requires Flash Player 10.0.32 or higher. Please downlo....." I followed the directions to a T and everything seemed to install/work fine. I'm on a Dell Streak running Froyo 2.2.2. It seems it's something to do with hulu.com not recognizing that I have Flash (your version 10.3) installed. My Netflix still works great though with your edited version of Flash. So at least it didn't break anything.
Any idea's?
I got that to... try installing flash from system/app. Worked after that.
Also, Netflix doesn't use flash to work, so it wouldn't affect it at all. All this is doing is hex editing the flash player and browser to make hulu think a windows pc is accessing it.
"try installing flash from system/app" - Can yu please explain what this is?
OP: what os do you have? Is it rooted?
edit: I see you have CM7 installed. is on the sd? is your nook rooted?
I'm on HC on sd card, unrooted. I installed flash & dolphin hd. But I'm getting Flash is required on hulu. Please help!
Thanks
I'm getting the same error too but I haven't had any luck with installing it from system/app. I also tried uninstalling, rebooting, installing from system/app, and rebooting again. Any other tips?
Yeah...
I bet the issues are caused from running it off the mSD card. Glad that it's working for you though.
That's what I figured as well...I just haven't gotten the nerve to root mine yet. I appreciate the fiddlling you guys do for us though....this is fun stuff!
Working for me on NC CM7 (7.0.2) running off 16gb Class 2 SD card. Honestly, it's very slow to load and choppy even off 288 and I'm overclocked to 1.1. But still, thanks so much!!!! We appreciate everything you do!!!
It looks like this requires a rooted Nook Color. Can someone please confirm that this does NOT work on a stock Nook Color?
FYI. Doesn't seem to work on unrooted Xoom. Hulu doesn't detect flash and asks me to install it.
I got it to load by uninstalling existing Flash through Titanium, rebooting, install new Flash... only way I could get the new hulu flash to work...
Do I have to root Nook first? There's no option for "Settings>Applications>Check the box next to Unknown sources" on Nook Color latest version 1.2.0.
Thanks,
I cant uninstall my flash player. It tells me its a system app and its greyed out in the manage application menu. HTC thunderbolt not rooted.
I'm guessing you most likely need to be rooted for this to work. Seeing as i'm on a rooted bolt and it worked perfect for me
The flash file won't install on the EVO. ehh i'm fine with netflix hopefully there is a fix in the future.
Going to try this later! Awesome find and write up!
Welcome to the forums. :)
Thank you!
As always great work on the video Huskermania. I have rooted my nook color,installed cm7, got neflix working and now hulu with your help.
Thanks alot!:)
When I try to install the flash_10.3-Hulufied... I got the error "application not installed"
Previous versions have already been removed.
If you get this error, make sure you power cycle your phone.
Thanks,
You're going to have to root you're Nook Color to get this to work. I have a few videos showing how to do this.
Rooting your NC via installing CM7:
Mac Version: YouTube - ‪How to Install CyanogenMod 7 on the Nook Color (Mac Version)‬‏
PC Version: YouTube - ‪How to Install CyanogenMod 7 on the Nook Color (PC Version)‬‏
Yeah, you're going to have to root to get this to work on the TB. The only way you can remove Flash is with root access.
Gremlin69
