How to Stream Hulu on the Nook Color and Other Android Devices
Quick tip, I do not have a Dropbox account but was able to send myself a Gmail with the Flash apk attached to it. It allowed me to install the apk from the email. Works like a charm!! Thanks huskermania!!
HA! Score on that! :)
Thanks!
Thanks! Got this working on my Epic 4G, had to add some steps, but it works. Flash player wouldn't install from the sd card. I had to push it manually through adb to /system/app then install it with a file manager.
whats the above QR for? loading the program or editing or what???? you get like me i say something usefull but dont tell everything and have to go back..now what about that QR
if it is still choppy after setting it to 288p, in dolphin browser try going into settings - more - advanced settings and uncheck "cache to sd", I noticed significantly better performance afterwards.
i didn't need to download another browser. in cm7, i just set the user agent in the stock browser to IE6 (a little embarrassing to act like i wanna use IE6), it works just fine.
So if I uninstall Flash 10.3 and then install the one you linked to here, won't that make it so other things won't work? Am I breaking a bunch of stuff to make one thing work? And will I be able to update this Flash app? I'd love to have this working, but not if it breaks anything else... especially my Netflix streaming :)
I'm running the CM7 mod off an uSD card on a Nook Color.
I went ahead and did this and the playback is really choppy. I'm running CM7 off a class 4 uSD card. I have a class 10 on the way, should be here today. I'll get CM7 on that hopefully tonight and I'll see if that makes any difference.
NookColor, stock 1.2, rooted with Manual Nooter
I have seen only one report of success with the above configuration - see reply 10 in this thread... Any other suggestions on how to remove Flash to install the modified one?
I think that it has been said that this will work on the Droid Incredible, but I am having no luck. I have Flash 10.3 and my device is rooted. I am unable to get flash completely off of my device. When I go to settings the only option I have is to uninstall updates which takes it back to 10.1 but still leaves it on the device. When I then grab the file out of dropbox it asks if I want to install and then states install failed. Cannot get past this and I would like it to work. Any suggestions??
I got it working, thanks for the tutorial! Just 1 quick question... Should I avoid all future updates to flash that appear in the market???
This was working great with the regular browser and then it stopped after the commercials. I went to Dolphin and it works again....weird.
Can any one post a different place i can download the apk file i cant seam to download it from the link posted thanks.
i was using the stock browser, but it got really choppy after awhile, so i switched to dolphin hd. everything works great now, except for some reason i cant lower the resolution. I can hit the settings (gear button), and the window will pop-up asking what resolution i want, but it wont let me select anything.
when i down load the file its a zip file i dont see a .apk . I unzip it i still dont see .apk. Any one have any ideas or able to post the .apk file else were. Help
Works but..
Like some others here; this works for me, but the video is still choppy at 288p. This is on NC running CM7. That said, I'm still glad that you took the time to work this out. It will be nice to access Hulu, even if it's choppy, when I'm on the road. Thanks.
Re: How to Stream Hulu on the Nook Color and Other Android Device
clicked on the link and got nothing?
you are the f'in man for doing this.
Worked on my CM7 HP Touchpad. Hoping for updates though ^_^
r3dpuk3
