How to Stream Hulu on the Nook Color and Other Android Devices
Re: How to Stream Hulu on the Nook Color and Other Android Device
i can't find unknown sources on my nook color how would i ind it? I went to settings....
It's a little choppy on my nook color but it's running off the SD card. At least it works. Thanks!!!!!
according to Hulu as of Dec 2011 Hulu is now supporated on the Nook Color - go to apps and download and you are good to go. No reason to hack the software.
Hulu plus only... Yes there is a lot of reason to hack the software.
Sent from space
Hey folks, found a more recent version of a Hulufied Flash apk here: [FLASH] Latest Hulu hacked flash
It didn't work for me on my NC, but just in case it's helpful to someone :(
So, apparently once I paid closer attention (gimme a break, I'm home sick on cold medicine) the reason it "didn't work" is I forgot to uninstall Flash first.
Remember to uninstall flash, install bilago's apk, set your User Agent in Dolphin HD to Desktop and enjoy Hulu!
PSA: Save time editing forum posts this year, don't mix Nyquil and sideloading apps.
Reactions: tube517
My solution. I am running CM7 internally with 32 Gig SD card for storage. Playon is installed on my Media Center PC (always on) and my Nook. When I start Hulu in Playon, video does not work.
I then hit the on-screen Home button, then tap the Playon icon which takes me back to Hulu.
From then on, when in Hulu, full video resolution is available on the Nook. Beautiful video.
I do use the "Hulued Flash apt.
Hope that this might help someone.
I get to Manage Applications but then it doesn't give me a Uninstall option for Adobe. When I try to replace the file with the modified flash it begins to install it but then comes up with an orange triangle and says Application not installed. Any help greatly appreciated!
Use an app with an uninstall function. I use zd box which has an uninstaller.
Sent from my NookColor using Tapatalk
Are you rooted stock?
My settings options do not look anything like yours. Yours looks like my android phone but my nook color settings options look nothing like that. is there something i need to update to have those options?
You need a custom rom.
Sent from space
I have an easier way. Download Flash Browser from the market and go to hulu.com.
Sent from my GT-P1000 using Tapatalk
I cannot access the link for the apk. How can I find it?
Thanks
The link for the flash player is not working! Please update!
The link for the Flash player is not working. Please do something! :'(
pramanj96
