[HOW-TO] Unbrick your phone using KDZ
Did all this, and my log looks identical to the one posted.
But I'm still stuck at the flashing "Android" screen.
Any help would be tremendously appreciated.
If your getting to the flashing android logo I think your Ok. Try holding home-volume down - power to boot to recovery it should take you to stock recovery, wipe data/factory reset then reboot
Tapatalk'n it from my VM670 running OM-Mandylion IHO on LS670ZVJ baseband
Hey, ive tried kdz.kp500,and lgnpst lgnpst says i have to many bad blocks ,kdz says i have an error towards the end ,kp500 flashes all and stops at 99% and then on my phone it only has an lg logo sooo im bricked ive tried all ls670 cabs and the zv5 cab and zv5 kdz sammyz said something about an lg optimus u firmware and that May be the only way to fix so yeah please help :(
If anybody can help me unbrick my LG optimus s i will literally find away to pay you by helping but that only if you can help- me unbrick this phone. Every time i turn on my phone it gets stuck on the lg or it gets stuck on the anroid logo please someone help remember i will pay if anybody can help. the phone is rooted.
Well... a bit more information about what happened would be helpful...
I looked through your post history and your only other post is in an ancient ZV9(?) rooting thread...
(flashing old ZV9 bootloaders and such onto a new ZVD or ZVJ phone would probably brick it, for example...)
So... what happened?
Can you access recovery with keybinds? (Home + Volume Down + Power)
Does ADB connect at all? (have LG drivers installed, and working ADB or get Android SDK)
... knowing that you see the logos alone (and not even the same one every time by the sounds of it? or different conditions? or...) isn't much information to work from.
hi,
did everything like you said, looked at 3-4 video about it, downloaded 3-4 version of thoses kdz file for my E975... and i still get everytime :
KDZ file extracted
Extract file error
==FINISHED==
can you please help me
thank you
LG p713:'(
12:38:40 : Launching SW update
12:38:40 : Unpacking KDZ
12:38:53 : KDZ file extraced
12:39:16 : Files were extracted.
12:39:16 : LGMobileDL Load.
12:39:16 : Port = -1
12:39:16 : Connecting to phone
12:39:30 : Check Phone mode = 2
12:39:30 : Phone type check.......
12:39:30 : LGMobileDL.DLL Loading....
12:39:30 : _SetAuthMark Fail
12:39:30 : _SetAuthMark Ok : wAuthMark(65535)
12:39:30 : _DetachDLL Call
12:39:35 : _DetachDLL Call End
12:39:35 : Param : Path = C:\ProgramData\LGMOBILEAX\Phone\P713_OPEN_AME.dz
12:39:35 : Param : moduleDir =
12:39:35 : Param : waitTime = 33000
12:39:35 : Param : UsbHighSpeed = 0
12:39:35 : Param : PhoneMode = 2
12:39:35 : Param : BinVersion = V10D_00
12:39:35 : Param : AuthMark = 65535
12:39:35 : Call fn_StartUpgrade
12:39:43 : 3GQCT : wParam = 2004, lParam = 5
12:39:47 : 3GQCT : wParam = 2004, lParam = 6
12:40:20 : 3GQCT : wParam = 2004, lParam = 7
12:40:23 : 3GQCT : wParam = 2004, lParam = 8
12:40:55 : 3GQCT : wParam = 2004, lParam = 9
12:40:58 : 3GQCT : wParam = 2004, lParam = 10
12:41:30 : 3GQCT : wParam = 2004, lParam = 11
12:41:33 : 3GQCT : wParam = 2004, lParam = 12
12:42:05 : 3GQCT : wParam = 2004, lParam = 13
12:42:07 : 3GQCT : wParam = 2004, lParam = 14
12:42:39 : 3GQCT : wParam = 100, lParam = 0
12:42:39 : Step : Upgrade Error error code = 0
12:42:39 : ResetStartInfo() Call
12:42:39 : _DetachDLL Call
12:42:44 : _DetachDLL Call End
12:42:44 : FreeLibrary Call
12:42:44 : FreeLibrary Call End
12:42:44 : ResetStartInfo() Call End
12:42:44 : 3GQCT : wParam = 100, lParam = 64
12:42:44 : Step : Upgrade Error error code = 64
12:42:44 : ===FINISHED===
TheGreatApe00
