HOW TO : UPDATE to 4.3 from STOCK 4.2.2 ( STOCK recovery, Locked/Unlocked Bootloader)
Upgrade to 4.3..... finished !!!
Works without any flaws.... very straight foward.
Now I'm on 4.3 !!!
Thanks guys !!
Same problem...
After a bit of searching to find out it is LOWER VOLUME BUTTON + POWER BUTTON,
I choose fastboot and it reboots to a red triangle with a "No Command" message and that's it.
Anyone else? Workaround?
same problem here...
There is no option in recovery. After selecting recvoery in fast boot : google logo... the android logo with a red triangle and under line it says: No command.
btw, for fast boot : vol. down + power :D
Any idea?
I was able to appply the update, but now i cannot download any apps from the playstore...it shows an error...anyone help??
I got it to work after some trial and error last night. I'm not very good with this sort of stuff but now I've got 4.3 on my Nexus with no problems and all my stuff still on the phone.
My problem is not the drivers ( unless you all think differently)
My phone is reconized. When i search for the device on CMD, its sideloaded.
But once I go ahead and type in the command adb sideload update.zip ( tried changing the file name, that did not work either), I get an error saying that it does reconize 'sideload'
I have the exact same issue too.
syylvr
