How to Voodoo ***Updated 27 Mar 2011***KERNEL BUILT FROM SOURCE/SOUND/UNDERVOLTED
If you can get by with: Back = Back and Home = Back.. It will be fine. Suffered through much worse options..
The joy of early release and learning the tricks of the trade.
Agreed..Just wanted readers to understand that there is always risk on these things... There are a lot of new folks just flashing away without reading...
Flashed the new kernel then wiped dalvik, re-boot is taking forever. Anyone else have this issue?
*Edit*
Wow. That was my first ever bad flash. It hung at the boot animation for 10 minutes and then entered the FCBLFH. (Force Close Boot Loop From Hell) Pulled the battery, three key pressed into recovery, and reflashed the kernel. Good to go now!!
Oh my goodness, the audio is incredible! My I-pod can now go die in a fire. Voodoo control + Slacker + SkullCandy TiTans = bliss...
Agreed! Except for me it is the following:
Voodoo control + Power Amp + Woodies = Freaking amazing!
Just to note: I was a sound engineer years ago, and this is the best sounding I have ever heard. So smooth and clean. Incredible.
Reactions: Landshark
Now you see y people like voodoo so much.
Sent from my SCH-I500 using Tapatalk
I do now! I have drunk the kool-aide.
I can hear things in my music now that I have never been able to hear before, on any sound system. WOW! :eek:
I love Voodoo! :D
On a serious note, anyone that is an Audiophile like me, try out these Woodies headphones. http://www.amazon.com/Woodees-IESW101B-Inner-ear-Stereo-Earphone/dp/B001U5YZ4G/ref=sr_1_2?s=aht&ie=UTF8&qid=1301251557&sr=1-2
Let them run non-stop for 30 hours to break them in, and then you have the best sounding set of anything. Period. They are on sale at amazon 20% off right now too!
So I got 2.9. 2 sc do I just flash the kernel and I'm good to go right?
Sent from my SCH-I500 using Tapatalk[/QUOTE
Yes, just flash the kernel through cwm if you are already on a voodoo kernel. If you are on a nonvoodoo kernel you will have to go into the voodoo section of cwm and disable voodoo lag fix before reboot.
is there a difference in the 2 zip files on xda?
Im thinking the one 0327.zip is the one with the home button fixed because right up above that in text it says " 3/27 Home button issue fixed!"
Im gunna try that one
That's correct. 0327 zip is the new one that corrects the home button problem. I already flashed it and home button is working correctly.
Reactions: briguyy
Hey with this to make music so sweet what's a good application to move music from my Itunes to my phone.
Sorta in the same position you are, I just need a good one to organize all the music I am about to dump onto my SD card. :D
Back one page in this thread member Cordoni suggested Power Amp. It's a paid app in the market similar to Titanium backup. You download the 15 day free trial version first, then buy the paid version which is just a key. Looks pretty good. Includes an equalizer so you can make adjustments to suit your taste. Plus I believe this is also the app that Adryanlyne recommends for using your phone in a car cradle and being able to listen to music while the phone is performing other tasks such as Nav.
Reactions: 10001110101
I've notice since flashing the new kernel my vibrate is EXTREMELY Weak, almost completely gone ..same for when moving icons/widgets to the trash, I don't get that zzzz feedback like I used to ..anyone else have this problem?
Nevermind, I just had to change my settings, I guess the flash kinda readjusted it ...sorry
kmerphone6
