Hows everyone battery life with 7.0
streetkilln
469
Honestly so far its not looking to good with me idk seems like im ending the day with less battery.. also my phone seems to be getting hot quicker than before.
Mine's been great. It was 100% this morning and at 9pm I'm at 63%. I'm loving it.
Great here too. Just picked mine up at 930am today. It's now 3 and it has lost about 5% (light use tho).
What I am surprised by is how weak the signal seems to be. I'm on ATT and my previous phone used to have 4/5 bars nearly everywhere....now I'm averaging 1 or 2 bars. Odd.
Oh, that's not what I needed to see, I just ordered mine today, and I'm on AT&T, cell signal has always been a problem with unlocked phones where I live. I'm using an Honor 8 now and it has the best cell signal of any phone, other than my Nexus 6 I use to own. I went with the Moto Z Play because I'm thinking Motorola, Qualcomm chip, probably going to have a good cell signal. Did you look at the actual signal in decibels? I know sometimes my Honor 8 will show 2 bars of signal but actually be sitting at something like - 90db. I have no problem with the Honor 8, just got use to a larger screen after using the Nexus 6 so long, that plus I'm getting old :)
Haven't done that yet. I used to know what the process for field test mode was...Do you know it? I've googled it without luck.
Edit: found it in settings. My current strength at home is -106. My understanding is -85 or lower is a good signal. Phone presently shows one bar where my 6P used to be four. Odd.
FWIW I did register the IMEI with ATT and have them refresh the device signal. No real difference. My brother lives half a mile from me and got one a few weeks ago ....He says his signal is just fine, so not sure what's going on. I can make calls and data seems to working just fine though.
My battery has gotten worse. I lightly use my phone. Before I would have about 3 hours SoT and be at 95 and now with 3 hours SoT I will have like 89 left on my battery
I've downloaded the update but am holding off on installing it for now. Wanna see how some of the issues I've been reading about here shake out before I hit the commit button.
I tried everything. Deleted cache partition. Reset the preferences on the battery settings. Factory rest. I may have gained a percent but it's still worse than before.
@Icemax60
After reading your post, I realized that when Huawei updated the Honor 8 to 7.0 I saw, and still am seeing about the same battery life difference that your seeing on your Moto Z Play. It's not a tremendous difference but on my Honor 8 everything works just fine it's just the small percentage of battery life that had dropped down. I am starting to believe that it may just be Android 7.0 runs differently and maybe consumes a little more battery than 6.0 did. Just a thought anyway.
My battery life was worse with 7.0 until I turned off wifi scanning and Bluetooth scanning under location services. Now it's noticeably better.
I have 1 and half hours of screen on time and now my battery is at 89% I think I am having some problems with doze. I just took an hour nap with 94% and now I'm at 89%
Okay so seems like the pass two days after restarting my phone before and after full charge it seems to be going well.
Days and days of standby with hours and hours of SOT. I know it's not a scientific analysis but the battery life is good. It's still new and I'm still getting all my apps installed/setup. If it drops by a third it will still be okay
Update for the captain's
question below:
Droid edition. I'm on VZW...
Can everyone who is posting please let us know if you are using an unlocked Z Play and which network or if you are using a Play Droid Edition on VZW and where you are located if you want to include that.
Just curious to see if there are any noticeable differences as I have an unlocked Z Play on AT&T in Austin Tx and am holding off on the update for just a bit to get a better feel for it.
might be a faulty radio antennas or something. try to return it and get another one
I have only had mine for a week and it updated right away so no reference to M. I worked last night so sporadic use. Did use it quite a bit before and since getting off.
Verizon
