Jaycemiskel
Trusted Member
- Jul 28, 2011
- 2,769
- 4
- 0
I'm glad I came from a Galaxy Nexus, it only got better lol.
Sent from my SCH-I545 using Tapatalk 4 Beta
How?When I boosted the power to the G3 antenna in my S3, the signal strength rocketed up.
Oh I see. It seemed like you found an internal solution to the S3 signal defect.
It's half a solution. I live in an area where 4G/LTE is only partially built out. When I bought the S3, to replace my Droid X, there were a lot of places that I could no longer make calls, reliably. The S3 signal kept shifting back and forth beween LTE, eHRPD, EvDO_A, 1xRTT. Even without the Wilson Booster, I improved my ability to make and receive voice calls, by shutting down the LTE on my S3. Apparently that is a violation of some Google "rule", even though there are apps on Google Play that claim to do it. A popular app for closing off LTE on Samsung Galaxy phones, last year, was called Phoneinfo. It was pulled from Google Play and there were reports that users were not able to restore LTE on their phones after using it. :-( What made me start thinking that it was a power allocation problem was when I used the Wilson Amp on the S3, when I had LTE disabled. In an area where the Droid X could typically get -65 dBm with the amp,(which is pretty darn good), the S3 got to -21 dBm! That got my attention.Oh I see. It seemed like you found an internal solution to the S3 signal defect.
I also moved from the Galaxy Nexus to the S4 and I am happy to report a very strong signal in compairson......although that may not be a good compareson because the Galaxy Nexus had terrable reception and switching problems. WiFi at my home show a strong signal but i am getting terrable speeds...I haven't looked into it yet but i suspect the problem is with the WiFi on the S4's (all my other wifi devices have good bandwidth).
On the Verizon 4g map I am in a solid 4g area however i must be directly in the middle of two towers. With my Galaxy Nexus i was alway switching between 3g and 4g but with the S4 i stay on 4g with good speed.....I get faster speeds with 4g compared to wifi for some reason..... good thing i have unlimited data!!
-Kesnik
Right now side by side my wife has a S3 and I have a S4 . She has ( The S3 -111 dBm and 29asu) I have (The S4 -95 dBm and 9 asu) I have no idea what that means, and if someone could help out on what that all means I would appreciate it, but those are our Signal Strength.
