How's Your GS6E+ Battery Stats?
Finally after 5 hours and having my Wifi at home on Cell Standby caught up and now using more battery then anything else. Surely this is a bug that can be fixed by Samsung or Verizon.
Over in the Note 5 battery thread we are talking about the same thing. Download GSAM and then post your cell signal graph. I have the same number of bars as you at home, and it seems that is considered "not good" cell signal.
This radio bug is affecting my wife and I. Hers is dead by 6pm without touching it. Thinking of returning.
Sent from my SAMSUNG-SM-G928A using Tapatalk
Battery life sux on mine with ATT. started out with 98% this am and as of 1240 pm down to 74% with less than half hour usage web surfing
Battery life was great for the first few days (24+hrs w/ at least 5hrs SOT). The past couple days though it has lasted well under a day with a little over 3hrs of SOT.
Thankfully I have extra Fast Chargers and should receive my Samsung Fast wireless charger next week.
Been using the heck out of it today so it won't last until the night, but as far as I can tell, battery life is good.
I went to sleep with my battery at 31%, I woke up 7 hours later and my phone was dead. I made sure nothing was running. Is this normal? It does pretty well throughout the day. I just want to make sure its not a defectivr battery. I even put my phone on battery save mode. Can anyone recommend a good app to make sure my phone doesn't have apps running in the background? My note 1 and 3 never had these issues. I still use my note 3 once in a while and does great on standby mode. Any ideas?
Just past the two week mark of being in my possession and the phone is still going strong for me, maybe later I'll put out a list of the things I've done (not very much) to keep my phone love me long time and stay perky :-)
Anyone experiences sucked drain battery on sprint network? Im curious thanks ya'll
I guess samsung need gone to rehabilitation to fix this issues as well.
4gb ram is no excuse.
Any other weird hiccup from this device?
Thanks in advance
Went through the day today. 2.5 hours screen on and I'm almost dead. Says Android is using most of my power. What is running that is sucking this much up?
I don't use Wallet but I use Now every day. I downloaded doze and have been tweaking stuff. Left my phone off my charger from 4:30 to 7 and it only dropped 4% so that's much better.
Not exactly thrilled with the battery life either. Overnight I kept my Edge+ and iPhone 5S off their chargers, sitting right next to each other, no apps running. Awoke this morning to find the Edge+ at 86 percent and the 5S at 100 percent. The ONLY difference between the two is that the Edge+ currently has the SIM card in it. So something tells me the cell signal - which is full-bar strong in our house since we use a Microcell - is the culprit.
Yeah I disabled Google now to see the affect, and sadly it was substantial. I'll turn it back on because most of the time I have wireless charges nearby, but the fact I can't change something to use less battery on in makes me sad
Use the battery stat app to see which part sucks the power. If it is the Android OS and Signal. I still have no clue how to fix it. Reboot the phone can temporary but not permanently solve the problem.
It is not a wise solution. But someday I will try to disable Google Now to see the difference. I still lose more than 10% juice overnight with all kind of data connections turn off.
cbbella
