HOWTO: WiFi Tethering - Working!
Status
Not open for further replies.
Just verified this on my device. You will need the following (after Rooting):
android-wifi-tether (I used 2.0.5-pre8)
wireless_tether_2_0_5-pre8.apk - android-wifi-tether - Wireless Tether for Root Users 2.0.5-pre8 *** EXPERIMENTAL *** - Project Hosting on Google Code
and from the Marketplace: tAttachApkInstaller
1. Go into Settings, select Applications and enable "Unknown sources".
2. Download tAttachApkInstaller from the Android Market
3. Download the android-wifi-tether application
4. When asked, open the file with tAttachApkInstaller
I'll try to post speed links later, but was able to tether my iPad with the default settings and navigate to Google.
why do we need the tAttachApkInstaller? wifi tether installed without it on the evo? i installed wifi tether on the epic as well. It doesn't work though.
what does the above install do that we cant do without? hmmm
Good question. Unfortunately, I'm still so new to Android that I couldn't currently tell you why. This is the method I used to make it work. :p
cant get to work, installed the tether apk, all look fine, but non of my laptops find it...help please
Thanks worked flawless and this is my first droid and first root. Just switched from WinMo after so many years
I wish someone would make a tutorial on how to do this for complete morons (like myself) because I've read other tutorials and other how-to's out there an i keep coming up empty.
Sent from my SPH-D700 using Tapatalk
Status
martacarl
