HTC EVO 3D: Issues and Problems...let's talk about them here!
Re: EVO3D Issues and Problems...let's talk about them here!
So I posted this earlier, but the answer I got didn't work for me. My battery stops charging at 99%. Last night, I charged it and woke up with it at 97% (It was at 82 when I went to sleep). Is anyone else having the problem of it not charging all the way to 100%?
My cord is tight as hell in the charging port
EVO - LUTION 3D
Yeah mine too, it's a real tight fight, almost afraid I'm going to break something when I push it in.(oh that's what she said)
My 3D pics are coming out crappy today...I put on an otterbox commuter case yesterday and it has the rubber covering the camera button, making it harder to press...I'm thinking that may be making me move and messing up the shots...I'll test this out a lil more later...
Having a problem the screen is flickering. This happens on the home menu, internet , etc. It happens random times and the only way to stop it is to press the sleep botton and it stops for a while then starts flickering again
I pressed the power button to turn the screen on, but the screen stayed black while the capacitive buttons lit up. I had to take out the battery and it worked fine.
Is anyone having issues with google navigation? Telenav works great but if I want to use google navigation it can never acquire the satellites. Just sits there with my location and says acquiring satellites on the bottom.
Google navi works for me. It picked up my location right away and acquired sats right away in navi.
My battery life is a joke. Completely died in 2.5 hours. I appear to be the exception. Also if I reboot, any app that is on the home evermore and the SD loses its icon. Reverts to the generic android icon.
I exchanged my original unit. They tested my battery and it was fine. Swapped out the phone and all is right with the world. Getting great battery life now.
Is the light switch from red to green? I think it's an issue with the way the widget that shows percentage is reading the battery. Sometimes my widget won't good to 100 but the red charge light turns green and if i go to settings and check battery all the bars are lit. So if this is the case then it's just a software glitch most likely.
EVO - LUTION 3D
this is my first android.... i'm a berry user... just gettin used to it, soooo umm the keyboard letters dissapeared... like it still recognizes when i touch the bottom where the keyboard usually is but its gray????
can anybody help?
thanks
For some reason, the icons of the apps I moved to sd card won't show the correct icon image after a reboot. It just shows the standard android image. I have to go into Manage Applications and force stop HTC Sense so it can refresh and show the proper app image.
This evo 3d, and htc sense is really slick. but to throw 2 cents out there, I do need a way to turn off the backlight on the soft buttons, they are sure bright. sounds like it took a root and a 3rd party app to turn it off on some other devices.
I can't seem to get HTC Sync to work. I couldn't find a 3D version, so I downloaded the 4g version. The found says sync can't be found on my PC and I can install from card, but I cannot find it on the card.
Is there a HTC Sync EVO 3D Version?
Yes this is a bug that many people are having.
A quick fix would be to change the skin. Once the sking is changed the icons show up again.
Definetly has to do with Sense and we need a fix.
Reactions: charles77k
Im having an issue where itll lock up on the preview shot in 2D camera mode and I have to reboot to take another picture.
I posted this before but does your video skip while the volume is adjusting up and down while watching a movie. This happens on netflix and watching green hornet. When I hold the volume up button it skips then stops when the volume is max. Same when u turn it down. Its fine when I press one at a time though. Its only when holding them down.
i am having more than a few questions.. and i tried researching to get an answer but couldn't find any.
Background: Original Palm Pre owner and WebOs fan (just got tired of waiting for the Pre3 on Sprint)
- switched my broken Pre for a NS4G.
- switched NS4G for EVO 3D
Issues:
1) for some reason this morning i was holding the phone on portrait and was searching the app catalog, web browsing, test messaging and a few other things that kept my screen from turning off and moving the phone to landscape. when i look at the clock on the status bar it says it is 0630, and then i look up to the tv on CNN and the actual time is 0640!!! when i realized the clock didn't refresh i stared and stared at it and sure enough another 2 minutes went by and the clock didn't refresh. it wasn't until i went to Sense homescreen and the HTC Clock refreshed the 12 minutes it had lagged behind but the clock on the status bar didn't. i performed a restart and they seemed to be OK. and then it happened again, only this time the difference from my wrist watch to the phone clock varies from a minute to a minute-an-half.... can someone explain to me how does HTC Sense refreshes the clock or time????
why does it take sol long for the phone to refresh the time when it is one of the most critical pieces of information any smartphone user can have?....does this affect the alarms?
PS: i have the Date & Time settings to Network Time.
2) while browsing the internet the Status Bar disappears therefore browsing at full screen... well, this is very very annoying because i constantly monitor the time and the battery status. as well as it make it easy to drop down the notification bar. And i find it very irritating to press the Menu button to bring the status bar along with the menu options. i tried looking at the setting to disable full screen browsing but can't find it, any ideas??
3) while listening to Pandora (as i have not added music yet to my phone) and a text comes in, the phone does the expected, lowers the Pandora volume and plays notification tone but you can still hear the music in the background. well my problem is that when i plug a headset or an AUX cable for car stereo and i am listening to Pandora and a text comes in, Pandora completely mutes and the notification tone is played through the Evo3D speaker, making it very annoying while driving. any ideas? suggestions?
4) my contacts are all a mess, same issues discussed on a different thread about cell numbers displaying on every incoming message. but i have a work around and use Go SMS.
5) stock keyboard was replaced by Go Keyboard because stock didn't give me the punctuation symbols on top of the QWERTY row like the stock NS4G did.
6) Bloatware: BIG ONE!!! and i am not just talking about Sprint Apps (as i do enjoy the NASCAR, Sprint TV and Telenav) but talk about HTC's amount of junk!..... can someone tell me how to delete Amazon, FM Radio, Footprint (what the hell is it anyway?), Friend Stream (i find it a bit redundant if you have the Facebook App, and i don't use Twitter or Likedin so i don't need it), HTC Hub, HTC Likes, HTC GUI, Mirror (just open the camera and switch to front facing camera), Peep, Quick Lookup, Reader, Sprint Mobile Wallet, Sprint Zone, Stocks (don't have any investments, yet).
yes i tried going into Application Settings, Manage Applications but none of these give me the option to delete.
7) what is Facebook for HTC Sense? is it an App, plug in? what's the point of that if you can download the Facebook for Android app??
8) is there anyway that the camera can take pictures faster? i mean, with my Pre i used to hold don the space bar and it would capture an image continuously. the NS4G didn't do it and Evo 3D doesn't either. this comes in very handy with two kids running around and needed to snap a very quick picture.
thanks for all your help. i really hope i can find some answers...
PS: not everything is bad, i really like the speaker, i think it is just as loud as my OG Palm Pre and quite louder than the NS4G.
I tried both and could not duplicate what you are seeing.
Oh man, how embarassing. Thank you though.
haha, yeah... and i don't even have the phone yet. no worries everyone has "one of those moments" every once in awhile:p
welma969
