HTC EVO 3D: Issues and Problems...let's talk about them here!
Re: EVO3D Issues and Problems...let's talk about them here!
My problems:
Lock screen ring. From the lock screen there are 4 icons, I had replaced the messaging icon with the Handcent SMS icon (my SMS app of choice). When unlocking the icons disappear before I'm able to encapsulate them with the ring. It always unlocks to the homepage instead of the app that I'm trying to shortcut to. Anyone having this issue?
App icons disappearing. After a reboot I notice many of my icons disappear. I have read that this is due to the launcher loading before the SD card is accessed. The easiest fix for me is to go into Settings -> Personalize -> Scene and apply a different scene than you are currently using and then reverting back to your original one. Your icons should all appear then. It's a pain in the ass but it works. Is there an easier fix for this?
How do I get the phone's drivers to use with Eclipse/SDK/ADK?
My problems:
you don't pull the ring to the app you pull the app inside the ring
Anyone else with this issue? Can't download youtube videos?
EVO - LUTION 3D
Is anyone else not getting a 100% charge? I enabled a pattern lock screen on my phone, and when the phone is charging the lock screen displays the battery %. It's been at 99% for the past 20 minutes. Any idea on how to get it all the way to 100%?
It will go to 100, mine did same thing. I thought same thing at first but it will.
EVO - LUTION 3D
i cant get my yahoo mail to work with the htc sense it just says no mail but if i go to it theough the internet it says there are new emails
That's weird, did you sync yahoo account?, menu, settings, sync accounts,,,, go down and sync yahoo?
EVO - LUTION 3D
EVO - LUTION 3D
yeah all that even tried changing the ports ans security type nothing its getting frustrating!! ahhhh
My phone keeps going back to home screen , I am look at something on the internet or pictures and within 2 to 3 minutes it goes back to the home screen. Did I miss the answer to this ?
Yes it is set to sync.
And I tried Google and it doesn't work either. Where is another option to immediatley get mail...wasn't having this problem until the 1.13.update.
Are you on wi-fi? Because if you activate over the phone your Internet doesn't usually work for 24 hours.
my evo 3d called one of my contacts all by it self and it did it again today, that kind of sucks because they will think im just playing or messing with them
Even after the updates - Enabling WiFI crashes on the phone - and seems to broadcast storm my network to the point all my other machines can't get out on the web.
Trying to get a wireshark capture to verify that - but needless to say every time I enable wifi, bad things happens. (Even showed this to the guys at the Sprint Store, and they said to do all the updates first...)
Just got mine today. It crashed on me about 10 times within the first 2 hours. I had on wifi with 4g. It would freeze and random reset. Turned off wifi and hadnt had any issues since.
Weird issue on mine with the touchscreen...it randomly won't respond to input at times, and then at others it will start taking a bunch of presses I did not make.
I already hard reset to try to fix this but it just came back now, anyone else experience this?
I'm going to give +1 to swype issues. Seems to have started after the htc update. The trace line doesn't show, and pressing sym doesn't change the keyboard to show numbers or symbols keyboards, though it still types them out. Either that or its just really laggy, can't tell yet.
CorpusChristi367
