HTC EVO 3D: Issues and Problems...let's talk about them here!
Re: EVO3D Issues and Problems...let's talk about them here!
My phone start acting strange since the recent update. It would just flip back to the home-screen while I'm on a webpage. No restart or anything. Very strange. I guess I will have to do a reset to see if this will fix the problem. Damn.
I'm having this problem also, and my phone keeps thinking i'm in a different time zone. Usually 2 hours behind where I currently am. Does anyone have any suggestions???
I think the last update mess my phone up. I never had this type of problem before.
Hi everyone, I've just literally joined this site, and I have to say I'm pretty impressed with the info on here.
I do have a problem though and it would be fantastic if someone could help me.
My EVO 3D has the usual apps and widgets however, I have a problem in that the widgets cannot be moved from the top of the screen to the bin. They seem to get stuck half way down the screen and stay grayed out. I've tried hard-reset to fix this but it doesn't seem to work..... has anyone else ever experienced this?
There is a note on this forum about and Asus that had this problem, but a reset seemed to fix it.....
Any help would be greatly accepted.
Thanks.
Im having widget problems. this problem happens after i rooted my phone, im definitely the rooting process is fine, cause previously i have root few phone for my frens. when i go to personalize settings, all my widget are gone. even i get a new roms wont get it back... any advise?:confused:
My friend every time he takes his phone out of a docking mode his sense reboots. Do you think an app is causing this. My sense reboots every so often but his does it every time he hits dock mode and closes it out.
Mine reboots when taking out of docking mode about twice a week. I never really gave it much thought because it does not really bother me. I chalk these things up to all devices do weird things sometimes, the people who say theirs does not are usually lying lol. Most likely a software glitch that will be corrected in a future update. I'm sure someone will come along and tell you you must root your phone to fix it. Lol.
Galaxy tab 10.1
I have had my EVO 3D for just under a week and there are three stuck pixels on the display (displaying only white). I have tried pixel fixers but they are not working, I find it very frustrating despite the smallness of the dead pixels. I'm possibly going to get a replacement.
when i answer or try to make a phone call i can,t talk on my EVO Design it wont work people keep on saying HELLLO that they cannot hear me what should I do
I recently had this and a few other issues, mine were supporting mobile conversion of web pages etc.. type Bing.com after it would convert to the mobile Bing, the browser would crash and other the same way, so I took it to Sprint and ran HTC's log system with the tech the then sent it ROM Kansas city to research the log, said the update had cause a crash of browser due to a massive memory dump which caused it to revert to the home screen. After I argued with them stating when i type anything random to the browser and it crashes. It should not cause the problems. After an hour ode this they gave me a brand new 3vo. Now I'm not updating it, its rooted and am looking for cm9 to put on it.
I am having issues with folders today. Once i open a folder i can't close it unless i either do a reboot or delete an icon from the folder. Anyone else?
EVO - LUTION 3D
Stock EVO 3D...Getting continuous Force Close messages for every app. I click Force Close - but the messages continue coming. I've restarted the phone multiple times and pulled the battery a few times as well. I can't access settings, etc - due to the constanct stream of Force Close messages. Thoughts as to what to try next?
Have you tried a factory reset yet?
Reactions: JustinC23
Exactly what is a "factory reset" - as in what are the steps?
Thanks for the suggestion. Performed a hard reset and now seems to be ok. Thanks again.
I can't figure out how to turn off my shutter sound on my camera....... I've tried turning my ringer volume to silent and my media volume to silent but neither works. Any one else have this problem?
There is no way to silence it. Funny, I never even noticed it to much until you mentioned it lol. It is not that loud to begin with.
Galaxy tab 10.1
So about a few weeks ago from one day to the next, my headphones were working so i figured i needed new headphones but then i come to find out that they are fine when i plug them into my laptop. So it turns out that my headphone jack mysteriously stopped working. Has anyone else had this problem and what was the solutions to fixing it in the end? Thanks! :cool:
I would try this,, shut device off and take battery out just to be safe. Take a cue tip and mostien it with rubbing alcohol,, gently insert into jack and spin slowly. I have done this in the past with other devices with same issue and it worked. Could be just dust.
Galaxy tab 10.1
Hi there.
I`m owner of my HTC Evo 3d for 3 months. It`s okey, only battery life really sucks:))
One week ago I got problem.
When I press on power button, to get off from standby mode, bottom buttons light`s up, then turns off, then light`s up, and screen enables, but this happens not always. I can press my power button 10 times, and there will be no problem. On 11th time, that annoying problem. Stock ROM. Tried soft reset, nothing...same problem. Anyone?
BarishYadav
