Bigleftyinaz
- May 23, 2011
- 119
- 0
- 0
also,Could any of this be cause if the Verizon rep dialed the update code *228.I hear this code will damage the Thunderbolt? I don't know if she did this or not.Just asking.
In reference to the 3g/lte toggle. Is it just me or are you not able to make any phone calls when it's toggled off?
Pretty close. EvDo does not give you voice, but when you're set to LTE Only in a 3G area you will have 1x data and voice. VoLTE will not work on the ThunderBolt, now or in the future. But that's probably far enough into the future that I'll already be on the phone after the phone after my dream phone.Depends on what your toggle is setting the radio setting to:
CDMA Auto (PRL): Same as a normal 3G phone
CDMA Only: Slow data speeds, but normal voice/text
EV-DO Only: 3G data speeds, but possibly no voice/text
CDMA + EV-DO/LTE Auto: Default. Uses everything.
LTE Only. 4G data speeds. Possibly no voice/text until they roll out VoLTE
I personally recommend using the LTE On/Off app. This way you have more control.
Chrisy said at one time she thought it was the network because of the other phones that weren't Thunderbolts that were rebooting. Well since that thread I had 2 reboots, however, they were both under the exact same conditions.
Both times I was in a basement that struggled to get a data signal, it would go to 3G and then back to 4G and then lose signal all together and it kept doing this until finally it just restarted. As long as I have a strong data signal (which is pretty much all the time because the network here is really robust and stable) then everything is fine. My phone has only rebooted 3 times since launch day, once was that time when everyone thought it was because of the update and the other two times were after the update and under the above circumstances.
This contact is for technical support only. You may contact our HTC American Headquarters at the
address below and they will forward your request to the appropriate department.
HTC America
13920 SE Eastgate Way, Suite 400
Bellevue, Washington 98005
Tel: 425-679-5318
I too was surprised. It was the HTC guy, not Verizon tech support, who said someone else would be calling me about sending me a test phone. It was very odd that he seemed to think someone would be calling me this 'long weekend' and wanted to know if I was going to be around. Maybe he does not understand the process of another department (or maybe he was just BS'ing me). If no one ever calls me, maybe I'll have some fun following up with him (have his first name & direct number) and his superiors. But I don't want to doubt him yet. I also do not think that I am an ideal candidate to receive a test phone because my problems are not that pervasive or bothersome.Interesting that someone in tech support would have the authority to offer a test phone. With all issues I been having having and open contact with HTC they said that was only authorized by the HTC NA Headquarters and would need to write them a letter or give them a call. Feel free to contact them and let them beyond Tech support know you want this matter fixed. Hourly rebooting of phones is not acceptable on any market and if you call and HQ isn't open your call with be put to normal Tech Support where they will suggest this is a known issue and to go into a VZ store and ask for an exchange and if VZ won't and tells you to wait for software update call back and speak to there RMA department and they will get you a new device. For this matter though it is hit or miss because not everyone is having issue so replacement device might not fix issue. They will also tell you if you ask about Test phones they do everything in house and do not offer such things to the general public.
And doesn't the LTE OnOff app just take you to the same hidden phone menu that all of the so-called 'toggle apps' take you to--I don't understand what you mean by more control, unless you're comparing it to EVO 4G toggles that don't work on the ThunderBolt anyway.
I don't think anyone has succeeded in developing a true toggle for the ThunderBolt yet, but if and when someone does, surely the toggle would change to CDMA Auto (PRL).I have not explored all the LTE toggle widgets and apps out there. I just know that any one app that gives you a simple On/Off options could be a bad idea, as you do not know what the "Off" is setting the radio to.
How did you get voice to work on EvDo Only? Or, if it was just a random experience, I wonder if it was simply a matter of the 'toggle' not locking in immediately. Sometimes the phone even needs to be rebooted for the 'toggle' to take effect.IAnd by the way, I have gotten voice to work on EV-DO Only setting, but sending SMS would fail about 70% of the time, and voice calls dropped regularly.
Again, sounds more like a software or tower glitch. I bet if you reboot, you will see the behavior I described above.When I switched it to LTE Only while in a 3G, I did not even get a 1xRTT connection. I assumed, however, like EV-DO Only that this was not a guarantee. Thats why I said it MAY cause issues with voice/SMS.
I was, but now I'm not so sure either. My source could be wrong, I suppose, and there is some grayness to the way some people use the term VoLTE.And I am not sure if the Thunderbolt will not physically be able to support it based on hardware VoLTE.
Correct.If thats the case, the only phone that has any different hardware is the Revolution, which already has made a VoLTE call ...
Incorrect.... and its only difference in hardware is an additional 1.9 GHz PCS radio.
It can't.I do not see how an outdated PCS radio could help with VoLTE calls.
That's true for the ThunderBolt, but, unless things have changed, the Revolution has the LG L2000 modem chip, at least it did when it shown off earlier this year about the same time that the test VoLTE call was made. Has that changed?They both have the same Qualcomm MDM9600 LTE radio.
There is some grayness to the use of the VoLTE terminology, eg, some people will even say that the ThunderBolt already does VoLTE (VoIP) when making audio or video calls over Skype on 4G. But that's not what I understand by true VoLTE. I think I've seen mention of other types of cobbled together VoLTE, but don't really understand the nuances.So, it is *possible* that the Thunderbolt could support VoLTE. Is it likely? No.
CONNECTIVITY - LG Revolution
• 1GHz Qualcomm? Snapdragon™ Processor
• LG L2000 LTE Modem Chip
• Verizon 4G LTE Network – faster download and upload
speeds than standard 3G*
• Simultaneous Voice and 4G Data – browse the web,
send email, or stream video while on a voice call
• 4G Mobile Hotspot – share 4G connection with up to
8** devices, download speed up to 12 Mbps, and
upload speed up to 5 Mbps†
• Wi-Fi? Connectivity: IEEE 802.11b/g/n
• Bluetooth? Version 3.0 Supported Profiles: headset,
hands-free, object push, advanced audio distribution
(stereo), audio/video remote control, file transfer,
phone book access
*When compared to Verizon’s standard
So I called back this HTC guy and let him know that nobody ever called me about sending out a test phone. He said he would check with someone and get back to me about what they would be doing about my phone, as in a warranty replacement, not a test phone. He said they had narrowed it down and they now knew what the problem is and a fix is coming very soon. So I asked him what the problem is and he said that they are not allowed to say because it is up to Verizon to communicate this to their customers. He seemed to be saying they weren't sending out any more test phones because the problem was solved. Or, maybe he never really understood about test phones not being sent to customers, and he was just covering for his speaking out of turn last week. But I hope he's right about the problem being isolated.I too was surprised. It was the HTC guy, not Verizon tech support, who said someone else would be calling me about sending me a test phone. It was very odd that he seemed to think someone would be calling me this 'long weekend' and wanted to know if I was going to be around. Maybe he does not understand the process of another department (or maybe he was just BS'ing me). If no one ever calls me, maybe I'll have some fun following up with him (have his first name & direct number) and his superiors. But I don't want to doubt him yet. I also do not think that I am an ideal candidate to receive a test phone because my problems are not that pervasive or bothersome.
Quite possible. But I don't want a refurbished phone. I'm sure they can't force me to take one. I was never looking for another phone, just agreed to speak with them to help them figure out what was going on.It sounds to me like you've been royally lied to. Lucky you, a brand old refurbished phone.
Certified Like New, I think, for phones that were returned within the 14-day period. They have another term for older phones.No, they can't force you take a refurbished phone. Although Verizon isn't using that term anymore. i don't recall off hand what their new PC term is for the refurbished things.
Honestly, I'm sorry to read that you aren't going to be receiving the test phone. I think that would've been really cool for you to get to do.
